turbo not spinning after warm up
Old May 5, 2008 | 02:09 PM
P'sS2k's Avatar
Default turbo not spinning after warm up
so i installed my turbo kit but the turbo stop spinning after it warm up, it could be the wastegate or exhaust leak? any info would help tia
Old May 5, 2008 | 02:21 PM
TRBOKEV's Avatar
do you have a little more info?
Turbos not spinning doesn't sound good.
Old May 5, 2008 | 02:58 PM
KnowledgeIsPower's Avatar
youve been around for 2 years. you should know by now there needs to be more information on any post like yours.
Old May 5, 2008 | 08:09 PM
P'sS2k's Avatar
sorry for the little info, so when i turned on the car everything runs fine, but after it warm up the turbo stop spinning or its lag n only spin slowly, i'm running the revhard kit with with a 38 mm wastegate n t3/t4 turbonetic turbo
Old May 6, 2008 | 04:19 AM
TelosHedge's Avatar
if the turbo seizes completely you usually can hear that happen. it's not a pretty sound. i do not think your turbo has stopped spinning altogether.
we still need more info. how are you controlling boost? do you have any CEL's? what kind of exhaust are you running? are you sure you've run your vac lines correctly?
how are you so sure you're turbo isn't spinning? are you monitoring with a boost gauge? what is it telling you?
Old May 6, 2008 | 07:31 AM
05TurboS2k's Avatar
ya I'm on a rev-hard kit myself. I'm curious how/why you think or guess it's not spinning.
Old May 6, 2008 | 08:51 AM
TRBOKEV's Avatar
Check the flux capictor to make sure it is getting full power.
Old May 6, 2008 | 10:49 AM
Vette2K's Avatar
Or maybe the hamsters are overheated.
Old May 6, 2008 | 01:40 PM
jwa4378's Avatar
I would check for boost leak / exhaust leak. But that would happen at all engine temps, not just when warmed up...
Have you driven it yet? Does it hit boost at all? Do you have your oil lines run ?
John
Old May 6, 2008 | 04:45 PM
Kwando's Avatar
i assume he has the filter off the intake of the turbo?
