turbo, now ac doesnt work?
Old Feb 24, 2012 | 06:42 PM
Dohntaut's Avatar
Default turbo, now ac doesnt work?
So i recently went turbo and everything seems to be working fine except my ac. It was working perfectly before i put the turbo in. I took the car over to get the ac system checked out today. They checked refilled the freon (it was a little low) and checked all the fuses and couldn't find anything wrong. They told me that its probably something electrical or a wiring issue, or maybe i shorted something out during the install. I cant think of anything that i could have done to affect the ac, possibly something to do with the ems?( aem ems 1052u).
Here is my build thread https://www.s2ki.com/s2000/topic/928...lesturbo-time/
if anyone has any ideas or suggestions please post them up. Thanks everyone
sorry if this is in the wrong section, thought it could be turbo related.
Old Feb 24, 2012 | 07:55 PM
TheSnail's Avatar
Sit there at idle and watch the rpm needle. Push the AC button and see if the rmp needle blips. If nothing happens, your compressor is not kicking on, and you fubared some wiring as your folks said.
Old Feb 24, 2012 | 10:42 PM
s2knoob89's Avatar
Did the shop check if the compressor was coming on?
Old Feb 24, 2012 | 10:53 PM
Dohntaut's Avatar
yeah they said that it the compressor wasnt coming on, and i probably shorted something.
Old Feb 25, 2012 | 04:29 AM
gsx2004's Avatar
it either gaveout or i know if there is no pressure in the lines it wont engage. It happened to one of my cars. Turbo burned through an a/c line and there was my issue.
Old Feb 25, 2012 | 04:38 AM
timg's Avatar
Turbo cars are also infamous for melting the heater control valve cable. The outer plastic melts into the inner cable preventing it from moving. As a result, the heat is stuck on whatever it was stuck on when it melted. Often AC does work, but is counteracted by that valve stuck on hot.
Tim
Old Feb 25, 2012 | 05:16 AM
DFWs2k's Avatar
one of the plugs (is there only one?) that goes into the compressor has been left unplugged a few times.
double check that it is plugged in.
Old Feb 25, 2012 | 10:03 PM
Dohntaut's Avatar
there is pressure in the system
everything is plugged up
and the control valve cable works. it can adjust from hot to room temperature
any other ideas?
if i did short something where do i begin?
Old Mar 3, 2012 | 10:12 PM
Dohntaut's Avatar
bump.. still no ac here.
Old Mar 4, 2012 | 06:37 PM
GoOn3's Avatar
I had an issue on my car that ended up being in the aem. Search Google for aem a/c issues and you'll be able to find where to look to make sure your a/c is "turned on".
Good luck
