Turbo Oil Catch Can Setup Options
Old Apr 4, 2017 | 10:41 AM
Mijae007's Avatar
Default Boosted Oil Catch Can Setup Options
Hey guys, I wanted to create a thread discussing oil catch can setups for boosted applications. There are probably more ways out there, but i drew up 5 different oil catch can setups that I am considering running. Im a visual learner so i have pictures. There are a lot of conflicting opinions on pcv valves and running open loop vs closed loop catch can setups. Here is what I learned. Ill try to keep it short.
The 2 main benefits of maintaining vacuum in the crankcase seems to be the idea of sealing the rings and pulling fuel-tainted fumes (blowby gases) out in order to prevent contaminating the engine oil. Catch cans are useful in that it will collect any oil and the oil/fuel particles in the gases to allow cleaner air to re-enter the intake system. Also, for us boosted guys, the increased pressure in the crankcase from the turbo setup could pop up the oil dipstick, or worse, cause ring/seal damage to various parts on the engine.
Below are 5 diagrams I am considering running on my turbo f22. Please review and discuss +'s and -'s to each.
Oem pcv to closed loop catch can, to supra pcv, to IM.
Crankcase vent to vented catch can, to intake arm on turbo.
Crankcase vent to vented catch can, to intake arm just before IM.
Both removed oem pcv and crankcase vent to vented catch can. Plug IM valve.
Both removed oem pcv and crankcase vent to vented catch can, to intake arm on turbo. Plug IM valve.
Both (oem pcv to supra pcv) and crankcase vent to vented catch can, to intake arm on turbo. Plug IM valve.
Old Apr 4, 2017 | 11:09 AM
King Tut's Avatar
Dual lines to a vented catch can is the way you are going to find the majority of S2000 owners turbo or not that run their cars on track. This is my old setup:
http://rio.ridedomain.com/engine.jpg
Old Apr 4, 2017 | 11:26 AM
Kenny_Stang's Avatar
I'm with his royal highness King Tut I, on a track car run both lines to a VTA catch can (option 3), no need to run another line to the intake.
Old Apr 4, 2017 | 11:46 AM
spdracerut's Avatar
Option 1 is the most OEM configuration.
You do NOT want to do #2. You will vent all your boosted air out the vented catch and also pressurize your valve cover.
Old Apr 4, 2017 | 01:29 PM
Mijae007's Avatar
Yea most of the setups i searched on s2ki ran it this way. I was just wondering if there was any functional benefit to running it any other way.
Thats good to know. So a big NO to option 2. I should take that image down not to confuse others. I was leaning towards options 1, 4 or 5 for vacuum cc setup. Between 4 and 5, not sure if utilizing the pcv would be effective being that its plumbed to a vented catch can. Itll probably pull very little vacuum given that its vented and hooked up to the turbo intake piping.
Old Apr 4, 2017 | 01:45 PM
If you run #4 or #5 then the PCV portion would basically act as if you had capped the PCV line. Reason is that you wouldn't get any vaccum from the line on a vented catch can, so running a line will do little for this setup. Really I think your two options are #1 (if you want to keep vacuum/OEM setup) or #3 if you are comfortable with a completely vented setup.
Old Apr 4, 2017 | 02:26 PM
nguyen365's Avatar
I do not currently have a catch can? i've been boosting around town for a couple of months. No issues is this okay?
Old Apr 4, 2017 | 02:32 PM
Spoolin's Avatar
In option 1, you're vacuum will only be beneficial out of boost and minimal at that and the only vent able to breathe would be the front one under boost, which is actually worse off for a boosted application. In a perfect world you would have a constant vacuum but that's not practical, so the next best option is to just let both vents breathe to atmosphere without any PCV. No need in over thinking and complicating things.
Old Apr 5, 2017 | 06:44 AM
Jaspah's Avatar
You will probably burn quite a bit of oil through the intake.
Besides oil consumption, you will also have a dirty intake manifold, more carbon residu on the intake valves, dirty sparkplugs etc... Better let the valve cover vent to atmosphere
Try option #3. This will work
Old Apr 5, 2017 | 07:02 AM
Spoolin's Avatar
And cause detonation.
