Turbo Oil Feed Setups
I'm running into an issue with my turbo oil feed line, i have a brass pipe from the hole, into a T, but the brass pipe keeps breaking... just want to see what you guys do, maybe i'm going about it wrong, wish i had pics to show how my setup is, but right now i'm at work so no pics...
I'd like to see how you guys are running it...
I don't know if it matters but i'm running AEM ECU.
ECU doesnt matter.
If your feeding from the oil pressure sending unit port (1/8 bspt) then you want to use short fittings. Not a Pipe.
If your feeding from an oil filter sandwich plate, then its generally a 1/8 NPT to AN fitting used.
Greg @ GO-AUTOWORKS
Greg @ GO-AUTOWORKS
I have a anodized T tapped into right next to the oil filter. With a line running to the top of the Turbo, and a sensor running off the T. ...I would think a T line from jegs etc would work better.
Sarek,
I'd like to order a heatshield like yours for a Full-Race ram horn manifold. Is it something commercially available or is yours custom?
Nice work! the routing and heat protection on your lines is very nicely done.
