Turbo Placement...
Old May 8, 2009 | 09:10 AM
Nickamsweet's Avatar
Default Turbo Placement...
Hey, since I have only really seen turbos on the LHD version of the s2k it was easy to relocate battery etc to allow space for the snail. It's just with the RHD all the master cylinders etc are over on the turbo side... I was just wandering if you need a manifold made to move the turbocharger around the front of the car or can it still fit in the normal place if i bought a Pfab or InlineP manifold??
Cheers in Advance..
Old May 8, 2009 | 12:03 PM
s2kadl's Avatar
RHDs also have the steering shaft that can get in the way.
Old May 8, 2009 | 12:06 PM
phils2k's Avatar
there are a few kits that fit our RHD car
the greddy kit and also the one i have which was custom built so that no stock parts were moved
i do believe there maybe another kit but i do not recall the ins and outs of it, aus has it i believe
https://www.s2ki.com/forums/index.php?showt...&#entry13852829
and heres my whole build thread
https://www.s2ki.com/forums/index.ph...ic=519057&st=0
Old May 10, 2009 | 01:03 PM
cheers mate, looks like a custom manifold is the best way to go then... just to make sure that all components that are heat sensitive aren't anywhere near the turbo (also so the thing fits in the first place).
Old May 10, 2009 | 06:40 PM
AusS2000's Avatar
I have the LoveFab V1 Minime Manifold and downpipe. It fits and doesn't interfere with the master cylinders or steering rod. You do have to move the ABS unit a bit though and make a custom heat shield.
S2kedwinn
Aug 28, 2016 07:53 PM
21k
Aug 24, 2009 07:50 AM
s.hasan546
Feb 4, 2008 09:56 PM
Honda_Mad
Dec 10, 2007 06:17 AM
Sinan'S2000
May 21, 2007 04:21 PM
