turbo plus nitorus
hey guys
i am looking to add nitrous to my turbo set up. i have a smaller turbo and i loose top end power at the track. i want to add a 50 or 75 shot on a button to use in 3rd and 4th gear. im not wantoing to use a direct port system. i also have 675cc injectors and they are maxed out. would nitrous require more gas when used. i know a bigger turbo would work but i dont want to add that yet
thanks
brandon
thanks
brandon
If your turbo is at the upper end of it's efficieny range and your injectors are maxxed out you'll definitely need either a wet system or an inexhaustible supply of engines.
Maybe provide a little detail about our set up and we can get a better picture.
