Turbo s2k braided lines
Hi guys, I need to order my fuel lines. What would be best? 8AN feed/ 6AN return OR 10AN feed/8AN return? Is bigger better or can you go to big? I just don't want to do have any limitations down the line and need to do them again to be honest? The turbo I'm running is a (gen2 gtx 3582r) and will be installing the sos twin pump surge tank.
Thanks for the help
Thanks for the help
This is brilliant thank's guys, so really up to 900-1000 hp -8 is fine but -10 for 1000+hp
Does anyone know if there's a downside to having oversized lines? I was thinking more fuel not being used going back to the tank constantly
being heated up
being heated up
Oh I see, the staged pumps are a good point, but as the -10 lines will hold a larger amount of fuel even with staged pumps there will still be more fuel circulating to the engine and back to the tank? Or have I got this wrong? I just can't help but think there must be a good reason people go for the -8.
Oh is it dependant of what fuel your using? Is that rite you need more E85 for the same power level?
