TURBO-SAFE SPARK PLUGS?
Old Aug 7, 2007 | 06:22 AM
05TurboS2k's Avatar
Default TURBO-SAFE SPARK PLUGS?
300whp = 1 steps colder
400whp = 2 steps colder
600whp = 3 steps colder
HOWEVER.... which do you run???
Oh and i hear good and bad about irradium...whats the honest deal. I'm going to just a little over 300whp in the next tune. (~325whp) Anyone?
Old Aug 7, 2007 | 06:35 AM
hokies2000's Avatar
http://www.s2000turbo.com/index.php?option...id=89&Itemid=28
IP used NGK BCPR7ES on mine. I'm at 380ish rwhp. This is 2 steps colder for me.
Old Aug 7, 2007 | 07:20 AM
AirborneS2K's Avatar
Also depends on your climate, as I am running 400whp and am only running 1 step colder due to humidity...I am wondering if anyone else in florida with my power numbers or slightly above is running 2 steps colder or 1?
Hokies, good reply, but he may not know your power output numbers...would be better if you posted them along with what spark plug IP used instead of just listing what spark plug they used.
Old Aug 7, 2007 | 08:21 AM
John_Z's Avatar
I run NGK 7405 which is a 2-step colder plug. No fouling and no mis-fires. Denso's are alright, but they seem to be more fragile than the NGKs.
If you're shooting for around 300 go with a 1-step colder plug.
Old Aug 7, 2007 | 11:38 AM
I'm assuming those are different from the BKR7IE which is ONE step colder...is that correct? Also, how have your plugs been holding up? I'm thinking of changing to 2 steps colder b/c I've been having a lot of backfiring and some breaking up @ mid-high ranger rpms (4500-7000rpm range) on occassion.
Old Aug 7, 2007 | 11:58 AM
hokies2000's Avatar
Ya, these aren't platinum. These are just coppers that won't last nearly as long as your iridium's.
I haven't really had the setup long enough to talk about performance but so far they've been doing well.
Hmm, Ya said these were 2 steps but it looks like maybe 1?
Old Aug 7, 2007 | 12:01 PM
OGPackin's Avatar
Im using NGK-R5671A-8, one step colder and im in South Florida 400+ rwhp
Old Aug 7, 2007 | 02:28 PM
ChefJ's Avatar
^ X2
Old Aug 7, 2007 | 04:40 PM
macprotege5's Avatar
aren't these plugs the same range as stock? i thought seven heat range was factory. currently i am using ngk plugs, but i am not sure of the number. i think the number is 7443. does that sound right? also i was told the 7443 is one step colder.
Old Aug 7, 2007 | 07:06 PM
chairmnofthboard's Avatar
what I used for Nitrous BCPR7ES
