Turbo Selection
So I'll be going the turbo route very very shortly and I've narrowed my turbo choices down to three:
GT3071R
GT3076R
GT3582R (I'm almost positive I don't need this)
My goals/predictions are 375 - 400 rwhp @ 14-16 psi boost pressure. That gives me a pressure ratio of just over 2 and a required mass flow rate of about 45 lbm/minute.
I've included the compressor and turbine maps from Garrett's website:
GT3071R
GT3076R
GT3071R
GT3076R
GT3071R
GT3076R
Looks like the two turbine maps are identical. I assume that the 3071 and 3076 use the same turbine?
On both compressor maps, if you trace a horizontal line along corresponding to about 1.9-2.1 pressure ratio, that will be my estimated performance line at full boost. Both lines pass through the meatiest portions of the maps, but it looks like the 3076 spends more time in the highest efficiency zones. 45 lbm/min looks like the absolute limit for the 3071 at a 2.0 pressure ratio, not to mention the efficiency at that point isn't ideal.
What do you think? I may have just answered my own question...
I myself am possibly going to be going to the T67 T3 flange turbo. I just can't justify putting a GT turbo on it when the journal bearing turbo's work great.
But I am also going for well over 400 whp.
Originally Posted by timg,Feb 6 2007, 07:52 PM
The GT3071R will make 400 whp with less lag. I have the GT3076R, but it's overkill for just 400 whp.
Tim
Tim
Plus, down the road when I free up my exhaust system a bit, I'll be flowing considerably more air at the same boost levels. I think its a good choice.
