turbo setup
Old May 15, 2008 | 09:32 PM
03silver2000's Avatar
Default turbo setup
Whats up .... time is finally coming, I have MOST of my turbo kit. Here is a list of what I got and one of what I need let me know if there is anything else I need... or if you think I will be able to hit 500 whp.
Have:
3mm headgasket cometic
hp performance manifold
3 inch downpipe
precision 600 intercooler
3 inch intercooler piping
60-1 turbo
tial 38mm wastegate
hks bov
aem ems 1052U
aem serial gauge(2)
gauge pillar
precision 880cc injectors
walbro 255 fuel pump
test pipe
3 inch megan catback
turbo xs dual stage boost controller
maybe forgetting some stuff.
Need:
map sensor
I think this is all... let me know if im missing anything, or if you think my setup will be capable of 500 whp
Old May 16, 2008 | 05:45 AM
bump
Old May 16, 2008 | 05:46 AM
USMCAP1's Avatar
Clutch
Diff (i need it to)
i go with a bigger intercooler and 1000cc injectors.
Not sure about that turbo but you might need an oil filter relocation kit
Old May 16, 2008 | 05:56 AM
the turbo, intercooler, and injectors are capable of 500. yah I need a clutch and diff also. I dont need a filter relocation kit
Old May 16, 2008 | 05:59 AM
USMCAP1's Avatar
Yeah they are i agree. I went with the 1000cc and intercooler upgrade from InlinePro, mainly because i dont want to have to replace it when i tune for more boost and C16 Clutch for sure though.
Old May 16, 2008 | 11:03 AM
Planets's Avatar
I would recommend an oil cooler and turbo timer since that turbo is not water cooled.
Old May 17, 2008 | 08:42 AM
TheCarGuy2021's Avatar
With those size injectors you may need an injector driver.
Old May 18, 2008 | 02:56 PM
datzlr's Avatar
whats aye injector driver?
Old May 18, 2008 | 05:50 PM
when using peak and hold injectors...injectors over 550cc typically need one. I believe rc750cc injectors dont need one. You can also use a resistor box from a older honda civic or older integra...or even 10 watt 10ohm resistors from radioshack.
correct me if im wrong but this is what is to my understanding.
Old May 18, 2008 | 07:40 PM
killabee's Avatar
03silver2000 you are correct. you can even use the clips from an older honda to run rc injectors. me I am going with 750 rc injectors which you do not need a resistor box.
