turbo Size
Old Dec 12, 2014 | 10:21 AM
denberbud's Avatar
Default turbo Size
i have an Ap1 that is getting boosted soon. I get so confused when it comes to turbo's with all the differet housings and A/R, trims, etc etc. As this being the FI forum, i'
m seeking your opinions and knowledge basis, to help me make an educated choice for my turbo sizing. my goals in mind are... I'm only going for a MAX of 400hp on the stock bottom end to start, with a custom tubular log manifold. then i will save to have the block sleeved with forged pistion and rods etc etc. At that point i'm going for 600hp on E85. My initial thought was going with a Gt35R, i dont want to go with a ball bearing turbo right out of the gate(can't rebuild a ball bearing cartridge/ they are expensive to rebuild in general) So my first question is What is the closest turbo size in a journal bearing to a gt35r in a precision brand? My second question is i had someone recommend going with a gt4088, one its a twin scroll housing, which from my understanding doesn't do well on f-series motors unless its a high horse power set-up, and isnt a 40 series turbo a tad bit big for the goal im looking for?
thank you
Old Dec 18, 2014 | 09:07 PM
turbodreamz22's Avatar
Pte 5858 that's what I plan on doing when I boost a s2000. Good spoil with good top end. Can make 400+who all day.
Old Dec 18, 2014 | 10:17 PM
spdracerut's Avatar
Here's an article on turbo sizing in general:
http://www.motoiq.com/MagazineArticl...e-Matters.aspx
Old Dec 18, 2014 | 10:25 PM
VitViper's Avatar
I'm running a Comp CT4X-5862. Makes 400 easily with fantastic spool and lays down over 600whp when pushed hard.
Old Dec 18, 2014 | 11:39 PM
riceball777's Avatar
400whp will be pretty hard to make on 91/93 octane with a log manifold. I highly suggest you save and go with a tubular manifold that has a proper merge collector and not a log manifold. A log manifold will hold you back 60-80whp on straight pump gas 91/93 octane.
Old Dec 19, 2014 | 08:13 AM
denberbud's Avatar
Ive seen first hand an s2k make 420hp on pump gas with a tubular log manifold. i have no worries that i can make 400 with that manifold. 600 is a whole different story yes. but the overall end goal is 600 on e85. so this beginning number is only because my current motor has a 135k on it haha. So a built bottom end is first before i go above 400.
thank you for the reply though
Old Dec 19, 2014 | 08:43 AM
Redline S2K's Avatar
But if you want 600 later on, why set yourself up for failure? You're going to have an uphill battle to get 600 (even with E or race fuel) on a log. Build it once and get a good tubular manifold now. What "tubular" log manifold did you see make 420? The only logs that come close to being considered tubular that I can think of are the Full Blown, Pfab, and Kings performance log manifolds and these still will become a restriction log before 600hp.
Old Dec 20, 2014 | 04:22 PM
lude92_si's Avatar
S200sx fmw made 600whp 420tq on my ap1 with great spool!
Old Dec 21, 2014 | 02:15 PM
ballistic1350's Avatar
What fuel? How much boost? Have a dyno plot?
Old Dec 23, 2014 | 12:47 PM
denberbud's Avatar
Originally Posted by Redline S2K
Originally Posted by denberbud' timestamp='1419009238' post='23442205
[quote name='riceball777' timestamp='1418978341' post='23441859']
[/quote]
i see how it may appear that i am setting myself up for failure with a tubular log manifold. But i am going into it with the understanding that i very well may have to have a new manifold made and re-work my downpipe to support 500-600hp in the future. Now i would love to go straight for the 600hp and be done but there is a lot of other supporting mods that need to happen before the can become a realistic HP goal. the "tubluar log manifold" that i have seen make 400-420hp is a product produced by LHT Performance in Tampa, FL. (not trying to sponsor anyone) He some really great photos of a couple turbo set-ups he has built. the "yellow S2K" is a close friend of mine and his put down 420hp with the manifold i'm speaking of.
