Turbo Spool up
Old Jun 8, 2006 | 08:06 AM
ideugene's Avatar
Yea it does look like the Full Race one.
That is one pretty looking part.
Old Jun 8, 2006 | 08:30 AM
S2KenC's Avatar
Originally Posted by spoiled@21,Jun 8 2006, 08:57 AM
Looks kinda like the new full race manifold.
There was a thread recently that stated that this is the same intake manifold Full-Race uses.
Edit....found the thread: https://www.s2ki.com/forums/index.php?showtopic=389992
Old Jun 8, 2006 | 08:35 AM
CaptKirk's Avatar
Originally Posted by Scorpion,Jun 8 2006, 10:55 AM
A single 3" actually isn't too loud. I have a duel setup that id rather loud, but found that capping one of the cans quiets it down a lot. I just pull the cap when I throw her down the track.
BOV has no effect on spool up as long as it's not venting while you are trying to build boost. Boost controllers can play a part, depending on design, but most don't do anything until you reach your desired boost level.
I am actually planning on getting a custom 3" dual that splits to 2 2.5" before going to the mufflers. I'm thinking magnaflow mufflers with oem tips right now, but we'll see
I was thinking the same thing about the BOV but I wasn't sure about the boost controller...
Old Jun 8, 2006 | 08:37 AM
CaptKirk's Avatar
Originally Posted by s0rted,Jun 8 2006, 11:25 AM
I've heard that as well, however when i took out my header I had a look at the exhaust ports and I'm sure it wouldn't hurt to smoothen the the ridges left by the factory casting process. Granted, it prolly won't make any huge increase in power, but a proper polish will aid flow, and consequently spool up.
Similarily, the stock intake plenum does its job well for NA, but if you're boosting you may want to consider soemthing like this:
http://www.gccorp.com.au/automotive/produc...products_id=152
Hmm I forgot about the intake manifold lol. Thanks
but my question is, yea this might get you more power...but would it help with the spool up time? theoretically it should I'm assuming since it improves the air flow for better induction into the engine, but just wanted to ask to be sure.
Old Jun 8, 2006 | 11:29 AM
slimjim8201's Avatar
I think the number one factor in spool time (besides the turbo sizing which is a given) is the manifold design. The whole spool process begins with the hot, fast moving air exiting the engine. The path it takes to the turbine is all important. A restrictive design will hinder your system performance, even if the turbo is sized properly. Look at the difference between the Lovefab systems and the Inline-Pro systems. Lovefab makes (by a long shot) the best mainstream turbo manifold on the market for the S2000. I've heard from a few owners with small to medium sized turbos (GT28-GT3076) that there is virtually no lag.
Old Jun 8, 2006 | 12:13 PM
CaptKirk's Avatar
Manifold efficiency in terms of producing HP is one thing...but would different designs affect the spool up? I ask this specifically because from what I've seen, the lovefab turbo setups and the inline turbo setups are very similar in terms of spool up rates. From what I have seen the spool up rpms for the same kind of turbos on each of these different setups is pretty much the same...
Old Jun 8, 2006 | 02:02 PM
AusS2000's Avatar
Apparently it is the same. Full Race's IM is made in Australia by Hypertune.
Old Jun 8, 2006 | 02:03 PM
AusS2000's Avatar
Originally Posted by Scorpion,Jun 8 2006, 10:59 PM
A mandrel bent 3" is more than most people ever need.
You do realise I was just using an extreme example?
Old Jun 8, 2006 | 02:45 PM
spoiled@21's Avatar
sorry to jack the thread but if hypertune makes the IM then how come you can buy theres already but FullRace says theres won't be ready till august? I will be ITBd and race stripped by then so I guess it doesn't really matter. wish it had come out last year though.
Old Jun 8, 2006 | 02:55 PM
copec's Avatar
Has anyone tried a cam with a more agressive grind before vtec? I bet that would have an influence on spool up and generate a large torque curve during spool-up to redline.
