turbo timer install - done as DIY shows but not working...
I have an Apexi Turbo Timer, installed as shown on this thread:
https://www.s2ki.com/s2000/topic/346...timer-install/
however, it will not keep the engine running. The timer will count down like it is.. but it just keeps the accessories on not the motor. To verify I'm wired right, I have:
Red to White
Jumper wired the two Black/Yellow together and tied in the Green
Blue to Black/Red
Black to Ground, Gray to ground (to bypass ebrake)
Is the gray to ground the problem? I wouldn't think so, I do the same with DVD players in cars so it'll play discs whenever. But I could be wrong, never wired up a TT before..
Red to White
Blue to Black/Red
i had a turbo timer previously from another car and tried using that writeup and got all messed up so i just went and bought the apexi timer
i followed the write up and mine worked. i did not hook up the ebrake either until later but it still worked
if you think you may have hooked up constant/acc incorrectly you can try the fuse box
