Turbocharged vs Supercharged
Old Nov 6, 2008 | 12:56 PM
LeonGalt's Avatar
Originally Posted by J'sBlackAP1,Nov 6 2008, 11:27 AM
I DD my turbo S and i have NO reliability issues. I don't see why one would be better than the other since the tune determines the reliability.
Besides, blowers waste gas
Why do blowers waste gas?
Old Nov 6, 2008 | 01:44 PM
CourageOO7's Avatar
I would like to know that too. Why do blowers waste gas?
Old Nov 6, 2008 | 03:16 PM
Moddiction's Avatar
Former Sponsor
He's probably referring to a roots or twin screw type of supercharger.
Old Nov 6, 2008 | 05:28 PM
MugenRioS2k's Avatar
people assume that superchargers waste gas because they are being driven at all times since that are directly coupled with the crank via the supercharger belt.
What people fail to realize is the designs of today have a internal by pass the opens under vacuum to prevent there from being any work done on the incoming air charge.
likewise the the TB is placed before a roots/twin screw to throttle the air charge at partial throttle angles.
So with a proper designed supercharger setup there should be next to no loss of MPH when cruising at a constant speed.
I allways get 30-32MPG on the interstate with my roots supercharger (averaged over 6 trips of over 600miles round trip.
Now the same argument can be said about turbos that they reduce MPG because they cause a restriction in the exhaust path.
With a turbo setup once the turbo is spinning at a nice steady state speed on the interstate there is effectively no drag in the exhaust system that would cause a reduction in MPG
Likewise the turbo speed is not sufficient to increase the pressure if the air charge there for no work is being done on the air charge.
The turbo/supercharger causing a loss of MPG on the interstate is like saying that I increased my MPG by putting on a lightweight flywheel.
Old Nov 6, 2008 | 08:12 PM
Opposite_Lock's Avatar
What kind of header/exhaust are you running? Do you also have a test pipe?
I would love to get 32mpg!
Old Nov 6, 2008 | 08:44 PM
AP2 Mugen header
AP2 Mugen cat back
Stock OD TP
Old Nov 7, 2008 | 02:46 AM
yiannakos's Avatar
IMO buy a S/C with stock boost , and you are done nice and easy
you go in the morning to the workshop and you leave it in the afternoon with at least 80hp more
easy and reliable
Old Nov 10, 2008 | 07:46 PM
TerminatioN's Avatar
Thanks for all the info guys.
Which one will get better gas mileage if driven exactly the same though?
Old Nov 10, 2008 | 07:53 PM
jbell's Avatar
Banned
i've actually heard of ct users getting better gas mileage when cruising with N/A guys in the twisties.
personally, my ct only used more gas when i was driving it hard, but that goes just the same for NA
Old Nov 10, 2008 | 08:06 PM
Randizzle88's Avatar
Go Vortech but don't drive like a asshole or there will be a hole in your gas tank lol
