turbos or superchargers
Old Jan 3, 2006 | 07:07 PM
slammo's Avatar
Default turbos or superchargers
i have a 01 s2000 what is the best setup turbo or s/c? what is the pros and cons?
my choose is ultimate racing turbo or a comptech. i need some info to make my decision.
Old Jan 3, 2006 | 07:14 PM
04RioS2k's Avatar
a search would be best but here I'm going to help you out with some info that I copied from a post I searched....
http://forums.s2ki.com/forums/showthread.p...ercharger+turbo
Old Jan 3, 2006 | 07:34 PM
ideugene's Avatar
Read up man. There's tons of info out there to help you decide.
Old Jan 3, 2006 | 07:53 PM
xviper's Avatar
There are "stickied" FAQs at the top of most major forum here. Those would be a good place to start.
Old Jan 3, 2006 | 07:57 PM
LUVNMBRS's Avatar
IMHO, I think the main difference is that a SC's speed is tied to crankshaft speed meaning you don't reach max. boost until max rpm. A turbo is not tied to crank speed cuz' it's driven by exhaust gases...meaning you can reach max. boost as low as 4,000 rpm.
This gives you much greater low end/mid range torque on a turbo. A SC is more reliable cuz' it's easier to map (the torque curve is close to a mirror image of stock, just higher) meaning you can use a rising rate fuel regulator and stock ECU, rather than remapping the fuel for that huge mid range mountain of torque on a turbo...just MHO
ohl05
Jun 5, 2009 04:20 PM
MANOS_BLUE
May 23, 2009 06:36 AM
S2PIDSTYLE
27
Oct 13, 2007 12:42 PM
MugenAp2S2k
Inland Empire S2000 Owners
43
May 2, 2007 09:49 AM
