twin scroll gt30r
As Ninja said, its not very efficient. The center division on the turbine housing causes turbulence which slows spool and lowers horsepower potential. The only times you should do this are when running a quick-spool valve, or unless its necessary (bought the turbo before the manifold).
Originally Posted by japancrx90,Jan 20 2011, 05:07 PM
cause i could a have a very good deal on a new gtr30
can i change de hosing?
how it cost?
all t3 is same hosing?
how it cost?
Originally Posted by ScorpionT,Jan 20 2011, 04:17 PM
Whats a "very good" deal? You may pay more in the end after you swap the housing. Not all T3 housings are the same, there are different variants. Swapping the housing is easy, you just remove the six bolts and two clamps on the backside.
