Ultimate racing turbo kit
Ap1 Tuned by fullblown motorsports.
Final numbers ended up being
492 rwhp, 356 rwtq
Dyno Dynamics so makes more then 500 on a different Dyno.
Ran out of Intercooler to small and need a oil catch can. Started popping my dip stick.
Set-up is
>Ultimate Racing Turbo kit
Still on LOG manifold needs to go
57mm t3/t4 turbo
1000cc ID injectors
Tuned on E-85 single walbro pump almost maxed.
19 psi
492 rwhp, 356 rwtq
Set-up is
57mm t3/t4 turbo
1000cc ID injectors
19 psi
i was unable to get anywhere near 500whp with the manifold and turbo that came with the UR kit. Are you on stock compression? E85 is a great gas to up timing on etc..!
Congrats on your numbers. lets see your dyno graph
Thanks for all the compliments guys. Its not on stock compression. It is a built inlinepro engine the only way i felt that this could be accomplished safely. 9:1 cp pistons and sleeved. I was def surprised with the numbers as well especially on the low reading dyno. I think it had alot to do with E85 which there is allot up here in MN. The turbo is for sure close to being maxed out the biggest problem was the intercooler. I have a custom sidewinder manifold being made write now and a Garret "Blowzilla" turbo to be on its way soon also a bigger front mount ill be going for well over 600hp soon.
Ill post the Dyno graph up tomaro.
