Username: blixhavn
Turbo/Supercharger Kit: Turbo Turbo/Supercharger Make/Size: 6266 Gen 2, 1.15 twinscroll hotside Motor: F20C Compression Ratio: 9.58:1 (final calculation) 10:1 CP pistons Supporting Mods: Pfab twinscroll, berk 3 inch Specs: Built Benson Block, CP rotating, supertech head Injectors & cc: FIC 1650's Fuel Pump: Walboro 450lph in tank, feeding SOS surge with dual 255's EMS: Kpro V4 Fuel: Husky 94 octane (10% ethanol) PSI: 16PSI WHP: 539WHP WTQ: 342WTQ Dyno: Dynocom Tuner: Turbogixxer Figured I should update this even though I'm going to be switching to haltech shortly. |
2 Attachment(s)
Username: 3XCstore AP1
Turbo/Supercharger Kit: Turbo Turbo/Supercharger Make/Size: PTE 6266 Gen 2 Motor: F20C Compression Ratio: 10:1 Supporting Mods: Sheepey Turbo Kit, Greddy Go Tuning Spectrum Elite, Clutch Masters FX850, Ballade Sports(BS) Throttle Body, BS TCT, and BS Timing Gear, Zietronix FlexFuel Sensor, Radium Dual Catch Cans, ATI Damper, AEM Infiniti, Hondata 4 Bar Map Sensor Specs: Laskey/ Benson built; Bensons sleeve, CP, Pauter, Supertech/Portflow head, Assembled long block by Laskey Injectors & cc: ID 2000 Fuel Pump: AEM 320 lph EMS: Infinity with Flex Fuel sensor Fuel: E85/91 PSI: 24 on E85/ 18 on 91 WHP: 616 on E85/ 486 on 91 WTQ: 381 on E85/315 on 91 Dyno: Dynapack Tuner: RRE Attachment 81771 Attachment 81772 |
Username: Dreaming_S2k
Turbo/Supercharger Kit: Vortech V2 Turbo/Supercharger Make/Size: SCi, 3.2" ASP Pulley Motor: F22 Compression Ratio: Stock Specs: ARP Headstuds / Everything else OEM Injectors & cc: ID-1000 Fuel Pump: Full-Blown 340 EMS: Flashpro Fuel: 93 Oct PSI: 10.2 PSI WHP: 387 (uncorrected) WTQ: 242 (uncorrected) Dyno: DynoCom Additional Specs: HKS 75mm single exhaust, 70mm Test pipe. Everything else OEM. Redline 8500RPM. Tuned by Joe @ Redline Performance Asheville, conditions 2250' Elev / 102F / 53% Humidity |
2 Attachment(s)
Turbo/Supercharger Kit: CT-Engineering SC
Turbo/Supercharger Make/Size: Novi 1220 Motor: F20 Compression Ratio: 11.0:1(stock) Specs: Apexi WS2 CBE, 70mm TB & 70mm IM, ACT PP & FW, OEM DP. Injectors & cc: 370s (stock) Fuel Pump: Walbro 255 EMS: CT-engineering ACM piggy back Fuel: 91 Octane PSI: 8 PSI WHP: 315 WHP WTQ: 197 WTQ Dyno: Mainline/DynoLog chassis dyno |
Username: manus2kpr
Turbo/Supercharger Kit: precision 62/62 t3hot 82 a/r Motor: F22c Compression Ratio:1.3mm(0.51") headgasket Specs: plm manifold,twin 38mm WG Ebay intercooler,custom 3"exhaust Injectors & cc: id 1000cc 95% duty cycle at Fuel Pump: aeromotive 340lph EMS: aem v2 Fuel: 93oct PSI: 16.3psi aem log ( dyno was reading 17.1) HP: 502wHP TQ:342wtq Dyno: dynomite Tuner: Manny (me) |
Stock F22C
AZ E50 fuel (no more E85 at their pumps) PTE 6870 https://scontent.fsnc1-1.fna.fbcdn.n...22890638_o.png |
I plan on taking that novi 1200 record ;)
Username: MorngWoodStewie
Turbo/Supercharger Kit: SOS TS MAX Turbo/Supercharger Make/Size: GT3582r // ATP Evo X 0.94AR Machined T-housing Motor: F22 Compression Ratio: 11:1 (Stock) Supporting Mods: Fluidampr // BalladeSport FI Clutch // Turbosmart MBC // SOS in tank up rated FPR // SOS 20 amp fuel pump relay wire kit // SOS 70mm TP // J's 70SS catback // SOS 3/4bar map sensor // Modified SOS TS Max DP, open dump // NGK Iridium No. 8 Plugs gapped down to 28 Injectors & cc: ID 1000 Fuel Pump: Walboro 255lph EMS: Flashpro Fuel: 92 Oct PSI: 11.8 WHP: 417 WTQ: 295 Dyno: Dynapack // 4th gear pulls Tuner: Sean Igawa @ Garagemunky https://cimg1.ibsrv.net/gimg/www.s2k...c1a575e8a9.jpg |
Username: makima808
Turbo/Supercharger Kit: Full Race FF Twin scroll Turbo/Supercharger Make/Size: Borg Warner 9174 EFR 1.05 Motor: F22 Compression Ratio: 11:1 (Stock) Supporting Mods: Act Hd clutch with ap2 flywheel, Berk 3 inch exhaust, Defi Boost Gauge Injectors & cc: ID 1000 Fuel Pump: Fullblown 340 EMS: Flashpro Fuel: 92 Oct PSI: 12 WHP: 484 WTQ: 334 Dyno: Dynapack // 4th gear pulls Tuner: Sean Igawa @ Garagemunky https://cimg7.ibsrv.net/gimg/www.s2k...8e10ded703.jpg |
1 Attachment(s)
Username: mijae007
Turbo/Supercharger Kit: pfab t3 elt topmount custom Turbo/Supercharger Make/Size: garrett t3 60 trim .63 a/r jb turbo Motor: F22 stock unopened Compression Ratio: 11:1 stock Specs: supertech dual valvesprings and titanium retainers Injectors & cc: dw1300cc Fuel Pump: aem 320lph e85 pump EMS: flashpro Fuel: e85 PSI: 13 PSI WHP: 435WHP WTQ: 331WTQ Dyno: DynoJet Tuner: import auto pros Additional info: act hd pp, oem disk, ap1 flywheel, sos fuel return kit, precision 600hp intercooler, synapse bov, hondata 4port boost solenoid, 2.5"-3" dp to challenge usa ta-r exhaust Attachment 76553 |
