Upgrade from a Novi 1000?
https://www.scienceofspeed.com/index...rger-kits.html
SOS still sells their conversion kit to get you a N1200 on one of the older N1000 CT kits. $2000 for the mount kit and a new N1200 blower. Like Junky said, you can sell off your old N1000 to recoup some money. It should put the blower outlet in nearly the same position. Close enough that a silicone coupler should take up any difference.
Yeah ive seen them go for that all day if you can still find one, sometimes cheaper. Most have an aftercooler. Might still get lucky to find an aftcooled kit for not much more then that. 3k is about the ave going rate. But they all come in various levels of equip, depending on if they remained a base kit with the rrfpr, or ran an EMS and ditched some of the base stuff, or moved to an fmic and got ride of the aftercooled set up etc.
Originally Posted by E4RTH WORM JIM' timestamp='1442354233' post='23747913
Then I had to purchased:
New vtec block, L bracket, pulley tension mount, isolator hat and sleeve bushes, pulley, belt..... Tax and shipping.
SOS don't sell the upgrade plate anymore. I tried. They said they'd put me on a waiting list and if enough people showed interest they'd then make and sell them.
Originally Posted by s2000Junky' timestamp='1442367597' post='23748065
[quote name='E4RTH WORM JIM' timestamp='1442354233' post='23747913']
[/quote]
They have done this in the past, they apparently are too cheap to fork out the initial investment to keep these on the shelf, so they wait, and buy up a dozen and then sell them off, cycle repeats. But never know when they will decide to do another batch.
I had an old comptech kit and all I needed was the SOS plate for the new NV 1200 blower, nothing else. Re used everything else Comptech.
fyi i just ordered the novi 1200 upgrade. they say there run of 10 plates will be done next week. with a natural finish it was 2150$ without any trade in so if you want it better call them/email. ct has gone cold no response what so ever wonder what i will do when i need new rubber isolater bushings
I would also make sure your comptech tensioner bracket has full movement with the blower installed before installing the SOS bracket with everything on the car. Unless they changed their design, the bracket hits the blower, not allowing full belt tension which is quite a pain in the ass...
