URGENT: 1/8" BSP adapter Vortech Install question
Old Jun 2, 2009 | 09:27 AM
SpeedxRacer's Avatar
Default URGENT: 1/8" BSP adapter Vortech Install question
I am trying to install the adapter that goes into the block that connects to the T fitting for the oil... does the adapter fit easily into the block? I am concerned with stripping the threads on the block if I try fitting it in since it seems like the adapter threads are a little bit larger than the Stock oil pressure threads.
need help asap
Old Jun 2, 2009 | 10:28 AM
m R g S r's Avatar
It should thread in just as easily as the stock oil pressure sensor. I haven't done a turbo install on my S yet, but every other honda motor I've threaded the 1/8" BSPT adapter into has gone in easily by hand. I always use teflon on the threads as well. Just be careful towards the end when tightening with a tool not to tighten it too much, the aluminum threads in the block strip easily.
Old Jun 2, 2009 | 12:41 PM
it didnt go in easily, it stopped at about 1 thread and after that I said no way im not going to force it in.
Old Jun 2, 2009 | 12:43 PM
devs2k's Avatar
This is 100% the adapter that came with the vortech kit, and not one you bought on your own?
Old Jun 2, 2009 | 12:56 PM
I bought a used kit and I used what was included, I couldnt imagine the previous owner using something else? I dont know I tried what was included and then I went to a specialty shop to see if they had something that would fit... I guess the previous owner didnt include the right part?
Old Jun 2, 2009 | 12:57 PM
I put the car back together anyways... wasted my time but thanks for the input.
Old Jun 2, 2009 | 01:13 PM
devs2k's Avatar
Maybe just go out and buy another BSPT fitting; does the fitting provided look used?
1/8 NPT is very similar but you do not want to screw that into your block
mcmaster will have it
Old Jun 2, 2009 | 01:22 PM
it did indeed look used, but it didnt fit... I emailed vortech to see how much it would be to order the new parts so Ill see how it goes.. Most likely sell the SC since I dont want to deal with it lol.
Old Jun 2, 2009 | 01:36 PM
kix's Avatar
kix
Buy this one... Took me FOREVER to find it... also took forever to ship.
http://www.fastfittings.com/product/28947
Old Jun 2, 2009 | 01:41 PM
Sideways's Avatar
Vortech does not respond to emails. Call them with credit card in hand.
