Vacuum at idle
Old May 11, 2014 | 05:09 AM
1SlowSi's Avatar
Moddiction if you're at -10" you might need to investigate.
Old May 11, 2014 | 05:19 AM
Moddiction's Avatar
Former Sponsor
Hmm I've been like that for years. Make correct boost as well.
Did a boost leak test and only found one tiny spot that leaked at higher pressure only.
Old May 11, 2014 | 07:34 AM
baZurk's Avatar
Mine is the same way Moddiction. I read from the AEM ems reading too not a boost gauge.
Old May 11, 2014 | 08:56 AM
Moddiction's Avatar
Former Sponsor
Ok good to know I'm not only one.
I have all emissions stuff removed and air pump. Maybe that makes a difference?
I'm reading from serial gauge.
Old May 11, 2014 | 05:55 PM
Geebs's Avatar
Im running at -10.8 and Im pretty much running stock other than fuel set up and stand-alone atm.
Old May 11, 2014 | 06:09 PM
vduber's Avatar
I have all that Removed aswell, it's possible you have alil vacuum leak somewhere but if it drives fine then whatever lol
Old May 11, 2014 | 06:10 PM
Slows2k's Avatar
There is a difference between psi and inHG. An accurate vacuum gauge is not something most have. Boost gauges tend to have have 2 scales, psi for positive pressure and inHG for negative pressure. Any multi cylinder engine should be steady at 18-20inHg at idle, sometimes slightly higher. Increased cam overlap or altitude above sea level will reduce.
My old 71 340 Small block Chrysler with a 284deg duration cam idled around 12-14 inHG.
Old May 11, 2014 | 06:12 PM
vduber's Avatar
Well I clearly went full retard when replying to that lmao
Old May 11, 2014 | 06:21 PM
Moddiction's Avatar
Former Sponsor
Must be why. Aem serial gauge I guess just shows -psi for vacuum.
Old May 12, 2014 | 12:14 AM
s2k manic's Avatar
my aem boost gauge reads 20-23
