Vacuum lines collapsing?
Old May 14, 2009 | 03:07 PM
S2KB00ST's Avatar
Default Vacuum lines collapsing?
Some of my vac lines are collapsing! I have a vac manifold and two of the silicone vac lines that connects to the MAP sensor and BOV seems to be collapsing from the high heat! I tried two different types and they both collapsed and I'm having some boost issues that could be caused by this
What kind of vac lines do u peeps use thatare more heat resistant and will not collapse?
Old May 14, 2009 | 03:16 PM
rob!'s Avatar
sounds like the lines you have arent too great. I have some lines run close to my manifold without any issues. I just got them from a local auto parts store.
Old May 14, 2009 | 03:20 PM
H.A.R.T B18C1EG6's Avatar
^true that. my lines held steady even next to my manifold.
Old May 14, 2009 | 03:53 PM
Boofster's Avatar
silicone lines are not that great
http://www.beyondthedyno.com/Blogs/Eric/?p=1401
Old May 14, 2009 | 04:48 PM
neeman77's Avatar
I use 3/16 fuel line, it has some structual integrity esp since those lines get hot.
Old May 14, 2009 | 05:05 PM
GDM S2K's Avatar
get these
race parts solutions sells them
Old May 14, 2009 | 05:10 PM
Slows2k's Avatar
The OEM vacuum lines can take 22 psi all day long. Just add a small zip tie to hold them on.
Old May 15, 2009 | 01:40 AM
S2KB00ST's Avatar
Originally Posted by GDM S2K,May 15 2009, 01:05 AM
get these
What kinda lines are these? THey look like vinyl.
In my previous turbo project I used the same lines without any issues but on my S for some reason they all turn like jelly lol
Old May 15, 2009 | 03:51 AM
GDM S2K's Avatar
The lines are made from nylon, I havent had one issue with them the fittings sit so snug nothing leaks,
http://www.racepartssolutions.com/products.asp?cat=103
Old May 15, 2009 | 04:09 AM
RichV's Avatar
I'm gaving the same problems with my silicone lines. They are fine in the straight runs, but with sharper bends, like the one coming off of the FPR seem to collapse. What problems could arise if that tube collapses?
