Valve Adjustment for Turbo Car
I have a turbo S and I'm going to have a valve adjustment done this weekend. I'm curious: should the valve clearances be adjusted any differently than OEM recommended specs? If so, what ranges should I strive for? If not, should the clerances be @ the tighter end of OEM spec, or looser?
I should also note that my block is sleeved, I have lowered the CR to 8.5:1 and my valvetrain is no longer stock (Ferrea SS valves, dual springs and Ti retainers).
TIA!
TIA!
Originally Posted by GDM S2K,Jun 12 2006, 10:38 AM
Check with Web, since they did your cams they prob have specifics on what to set things at
leader
Κινητήρας - Μετάδοση - Περιφερειακά
May 9, 2009 09:07 AM
