Vibration from Full-race manifold
Old Dec 21, 2007 | 08:16 PM
stantaur's Avatar
Default Vibration from Full-race manifold
Is it just me, or does everyone with a Full-race manifold experience more vibration than a stock S2000 through the steering wheel, gas/brake pedals, shifter?
Doubt it's the clutch, as I have an ACT pressure plate and OEM Honda disc. 46K miles on trans.
Setup is a Laskey 9:1 short block, Stage 3 ported head, FR manifold & downpipe, GT3076R turbo, AEM ECU, Walbro 255 pump, RC 1000 injectors (in case I went E85 or upgraded later to GT35 turbo).
Thoughts?
Stanford
Old Dec 21, 2007 | 10:14 PM
Reborn56's Avatar
I've had my kit on my car for close to nine thousand miles now and no vibrations anywhere
Old Dec 21, 2007 | 10:38 PM
Tyraid2K's Avatar
Cracks, my last tubular manifold was shaking my car to pieces, turns out it was cracked up all over...
Old Dec 22, 2007 | 05:16 AM
Tolgahan Ures's Avatar
No vibrations for me .
Old Dec 22, 2007 | 07:05 AM
PeanutButter's Avatar
Nope
Old Dec 22, 2007 | 08:22 AM
jdnissanz's Avatar
No vibrations for me!
James D.
Old Dec 22, 2007 | 09:04 AM
Reborn56's Avatar
Let me reiterate that i have had no issues with the AUTHENTIC fullrace manifold.
Stuff thats not robotic welded im sure wont be as strong and perfect as the robotic welded ones
Old Dec 22, 2007 | 02:10 PM
stantaur's Avatar
Did you guys mount a brace from the bottom turbo/downpipe bolt to the block? Mine's an authentic FR, so I'm a little concerned.
Also, is anyone using the V-band turbine housing instead of a 4-bolt turbine housing? ATP Turbo has the V-band, and after looking at how hard it is to access the top bolt, I'm considering yanking the whole manifold/turbo combo and getting a V-banded turbine housing. My top bolt (of the 4 for the downpipe/turbine junction) loosened but the other 3 were tight.
Using Allen head bolts there -- anyone using studs instead?
Thanks again,
Stanford
Old Dec 22, 2007 | 03:46 PM
foxer10's Avatar
No vibrations after a year. Is the compressor hitting the frame?
Old Dec 23, 2007 | 07:08 AM
stantaur's Avatar
Compressor has ~ 0.4 inch between it and the frame when the motor is just sitting there (not running or under load). I've clearanced a hole that allows the compressor to rock to the passenger side to clear it. There's no increase of buzz based on load (which would be the case if the engine was rocking), it's purely RPM dependent and does it whether there's load, no load, coasting.
Good thought though. What kind of static clearance to you guys have on Full-race installations?
Thanks,
Stanford
