Vortech 10psi
I want to go 10psi in MY04 vortech supercharged S. From the research I have done I believe I need a 4" pulley,750cc injectors, and AEM 1052 to get the best tune. Is there anything else you guys would recommend or anything Iam missing that I would need. Is the AEM 1052 direct plug in or would I need a harness and the same for the RC750 injectors. Thanks for the ihelp.
your ems is plug and play, i mean plug and tune, 750 injectors are more than enough, just buy the clips from RC that dont make you splice the wires. Im in the same boat and going up to a little over 10psi. i will be getting dished valves and springs/retainers. i will proballu go oversized on the exhaust valves and stock size for intake.
You can either get the GM or AEM Map Sensor. BTW, I think a 2mm Headgasket would be good too
