Vortech BOV Question: Is this a NO NO?
Old Jan 6, 2010 | 02:05 PM
masksqueeze's Avatar
Default Vortech BOV Question: Is this a NO NO?
I have the V2SQ, with the factory Vortech BOV. I read somewhere a while back that the copper colored, conical filter was a silencer and that by removing it woke up the BOV a bit. Well, I removed it, car does sound different, but my question is, is this a bad thing to leave off? Reason I ask, I can't find the damn thing. It fell off my wrench and is now somewhere on the road or on the bottom of my engine bay. I don't know if replacing it is even necessary, all help is appreciated.
Thanks,
Jared
This....????
http://www.superchargersonline.com/product...=40&image1.y=17
Old Jan 6, 2010 | 08:51 PM
jefferyg32's Avatar
Those are called Stone Filters i believe. Necessary probably!! Would i find it and put it back on YES!
Old Jan 6, 2010 | 11:21 PM
That's odd, I found this searching here, but want a more current answer.
The filter is for CARB. Because there is a blow by tube that enters the intake air passage there is the possibility the air has some oil vapor in it. The filter is to keep the vapor from leaving the intake. Smog considerations aside, it is not necessary.
Old Jan 7, 2010 | 12:49 AM
I found this .pdf here explaining it's purpose.
What do you guys think?
http://fabco-air.com/pdf/Sec_14.pdf
Old Jan 7, 2010 | 07:57 AM
Called Vortech, they said it was to protect the diaphram from
debris, non-issue. Ordered a replacement for $12 shipped
Old Jan 7, 2010 | 05:20 PM
Sideways's Avatar
Those words look familiar. That quote is for the filter on the outlet and not the scintered one you removed.
Old Jan 9, 2010 | 09:27 PM
Moddiction's Avatar
Former Sponsor
Yeah there is a separate filter that goes on the outlet that is what is being mentioned above not what you show in the picture. 2 separate things..
Old Jan 9, 2010 | 09:58 PM
TRBOKEV's Avatar
Mcmaster carr sells em for less than 2 dollars.
Old Jan 9, 2010 | 10:20 PM
Spoolin's Avatar
Thats a sintered filter and yes, you should be using it.
Old Jan 9, 2010 | 10:31 PM
9kFever's Avatar
haha, did you already remove the other filter? Everyone is talking about the filter that goes on the output
cordycord
Jan 13, 2005 02:55 PM
bubbletrubble93
May 25, 2004 07:09 AM
JohnChan
Apr 28, 2004 12:35 AM
73Zero
Mar 18, 2004 02:15 AM
S2K
Sep 12, 2002 09:01 AM
