Vortech going for ~14psi Friday.
Originally Posted by ILoveMYHonda1984,Mar 12 2010, 09:39 PM
Stock CR is best w a S/C. Im glad to see another high powered s/c car in the works. Good luck! Im looking forward to seeing the results!
Originally Posted by Mrfixit687,Mar 12 2010, 11:19 PM
So is the limit pretty much around 11-12 psi on 91 octane without meth?
Originally Posted by nsx_bob,Mar 12 2010, 08:16 PM
List of what im doing:
AEM meth injection 50/50
AP1 intake cam/ AP2 exhaust cam
4inch intake elbow
not sure of the pully size on order but its good for 14-15 psi. Probably 3.5/6
valve adjustment
retune
4inch intake elbow
valve adjustment
retune
Oh, and careful with that meth. With the pressures you are talking about you should not need it on pump. I would highly recommend doing a secondary nitrous tune using it and not run it very often.
Originally Posted by camuman,Mar 13 2010, 07:12 AM
i wouldnt rev an stock ap2 that high. its not valve float you should be concerned with, its piston side load. longer stroke typically means less revs but broader power band.
Originally Posted by nsx_bob,Mar 13 2010, 02:43 AM
its not really a limit and above 12 psi can be done without meth but not very safely.
Originally Posted by iApex,Mar 13 2010, 09:55 PM
Sure it can. It's all in the tune. I'm running 14psi on 91 with a comptech set up tuned at Autowave. IMO the tune is everything. That's why you want to make sure you take it to a very knowledgeable tuner like Mike at Autowave.
