vortech install help
Old Mar 25, 2011 | 08:43 PM
sarge1's Avatar
Default vortech install help
Do you guys know if the vortech timing box and the map controller is in the same blackbox or is it two different box? I got the kit used and was trying to install it while my tuner did the engine bay stuff and I did not see the white wire. I looked at the diagram and I don't have the same amount of wires from the black box seems like I'm missing 4 wires.
Old Mar 26, 2011 | 07:54 AM
Moddiction's Avatar
Former Sponsor
There are 2 boxes. One is the timing box(larger black box) and then there is the MAP block box to hide boost from the ecu.
Old Mar 26, 2011 | 09:45 AM
trich101's Avatar
I don't know if you have one already, but here is the official install .pdf from Vortech. http://www.vortechsuperchargers.com/...20-010v4.0.pdf
Old Mar 26, 2011 | 09:49 AM
sarge1's Avatar
Trich I saw that I have a 01 and have a 04 kit. The 04 kit didn't come with a map clamp from vortech so if I install this it should work right?
Old Mar 26, 2011 | 09:54 AM
sarge1's Avatar
*01 s2k and a 04 sc kit
Old Mar 26, 2011 | 03:20 PM
Moddiction's Avatar
Former Sponsor
You need something to hide boost from the ecu or it will throw codes and not run right. I have a comptech ESM if interested. It is what comes with the Comptech sc kits and should be a better one compared to the vortech one. Can also get a Blox map block spacer or something. I had hesitation issues using one of those however.
Old Mar 26, 2011 | 05:15 PM
Slows2k's Avatar
The 04 Vortech kit had 1 box that ran timing retard, MAP voltage clamp and aux injector control. The 00-03 kit has 2 boxes, 1 for timing and 1 for MAP voltage clamp.
Old Mar 26, 2011 | 08:33 PM
Moddiction's Avatar
Former Sponsor
Ah ok nevermind then lol. Didn't know they were different like that. Good to know.
Old Mar 26, 2011 | 08:55 PM
sarge1's Avatar
Thanks slow s2k. It doesn't make sense to me. There's no wire that tap into the map sensor off the ecu so how would the black box hide boost from the ecu?
Old Mar 27, 2011 | 07:22 AM
Slows2k's Avatar
Have you verified you have the right box for a 04 kit? Do you have a aux injector in the aftercooler?
