Vortech just installed...
Old May 29, 2006 | 06:06 PM
AllStock27's Avatar
Default Vortech just installed...
Ok, almost done with my vortech install (just need the fuel pump done and "tee" the timing comp to the manifold n i'm set ..)... Everything looks good, no leaks, visual checks ok, but i noticed a slight "rattling sound" at idle... Is this normal? Everything seems fine, just driving it below 4k for now... I want to check it out now but its a lil too dark right now... atleast there's not check engine light! *cross fingers.. Just wanted to see if this is normal.. Thanks!
Old May 29, 2006 | 06:11 PM
Slows2k's Avatar
It's normal gear backlash inside the SC's step up gear drive. All centrifugal SC's make some noise.
Old May 29, 2006 | 06:20 PM
AllStock27's Avatar
ahhh, just what i wantedt to hear.! I was nervous because the sound was coming directly from the S/C unit it seems.. THanks !
Old May 29, 2006 | 11:03 PM
9kFever's Avatar
Yes it is normal, mine does it too. I thought forever that mine was way lousder than everyone else because I heard Viper's video. But I have heard numerous Vortechs and they soudn the same. You probably wont hear it as much when you do a cold start and the revs are about 2000 rpms.
Old May 30, 2006 | 04:28 PM
S2000 Cabrio's Avatar
Same here...rattling and grinding noise. They're just normal and it's a matter of getting use to the sound.
isaiahschang
Jan 9, 2011 09:12 AM
fflatulip
Aug 20, 2007 09:13 PM
xviper
Mar 18, 2003 03:11 AM
