Vortech Supercharger labor cost?
You should definitely look into installing it yourself. Not just for the $$$ savings, but you'll also learn some valuable information about your car...definitely handy for times when you need to make any adjustments/repairs to your engine or S/C.
If anything, you might wanna arm yourself with the proper tools, set aside a decent amount of time (you don't wanna rush it...personally, it took one whole weekend to install my CTSC), and having the Helms manual around wouldn't hurt.
Good luck!
Good luck!
if its a new kit, go ahead and give installing it yourself a shot. even if you get to a point where you have to throw in the towel and taking it to a shop, all you really need to do is throw the air box back on along w/ the vac. lines. No step in the install process take you to a "point of no return" situation really, cept maybe tapping oil pan w/ vortech which is easy and you could outsource if u get stuck. You've got notihng to lose really cept maybe a few hours of your time, and you could save yourself a chunk of change and gain some valuable knowlage about your FI set up.
wires might give you a har time, if thats the case, throw on the unit, leave the belt pulled to the side, and drive the car to a pro and just have them do the wiring. you will still learn a ton.
Dont want to go a lil bit off topic here but since its about Vortech SC.... Any folks out there know about Supercharging a MY07' S2000????? I preffer Vortech than Comptech but either way works but I can not find any that is specifically FIT to 06-07ap2.. Has anybody know about fitting the SC kit for the 04-05 to 06-07??????
Any info would help... I cant wait to SC...
https://www.s2ki.com/forums/index.php?showtopic=546481
Kondor999
Jun 14, 2007 07:15 AM
