Vortech V2 Aem ems V2 base map
Old Sep 13, 2012 | 07:48 AM
MPS2000's Avatar
Default Vortech V2 Aem ems V2 base map
If possible can I borrow a Map for the setup below running on AEM ems V2? it will be very much appreciated. thanks
f20c
vortech v2
pulley size 3.55 inch
bosch cobra water pump,
ids1000
aem ems v2,
70mm throttle body, 4 bar map sensor
310lph fuel pump,
76mm manifold, decat and single exit exhaust,
cc stg4 clutch and light flywheel,
mishimoto rad,
19 row motul oil cooler,
sperco large heat exchanger,
mugen thermostat and fan switch.
cam keys
and few more mods which i dont remember as of yet.
Old Sep 13, 2012 | 12:28 PM
Reapur's Avatar
Disconnect the belt on the blower, run oem injectors and drive to the tuner NA. Once you're there, install the belt, injectors and ems and let the tuner get the correct base map to get you going.
Old Sep 13, 2012 | 05:00 PM
tom153's Avatar
You have to take the blower off to remove/put the belt back on.
mps2000, PM your email, I think I've got you covered.
Old Sep 13, 2012 | 07:15 PM
Reapur's Avatar
That doesnt sound right at all, you would just loosen the screw type tensioner pulley and remove the belt. Removing the blower each time would just be retarded.
Old Sep 13, 2012 | 09:04 PM
tom153's Avatar
Loosening the tensioner would only allow you to adjust the belt. Look at the diagram below and note the lower two bolts that hold the sandwich plate in place - that plate has to come off in order to install the belt. BTW, the red dots mark which bolts/nuts have to come off to remove the blower.
Old Sep 14, 2012 | 04:21 AM
camuman's Avatar
Belt can be removed without removing blower. Others have done it. U have to remove a bolt then it slides past it.
Ask tuner for base map or trailer car to tuner. I trailered mine. Uhaul trailer ftw
Old Sep 14, 2012 | 05:16 AM
Moddiction's Avatar
Former Sponsor
That's not true. As someone else mentioned that just adjusts the tension on the belt.
You can remove the 2 bolts that hold the ottom spacer to the engine and loosen a few other bolts slightly which will allow you to pull the belt off and then slide it through and off the car.
Old Sep 14, 2012 | 09:39 AM
Reapur's Avatar
Originally Posted by Moddiction
Originally Posted by Reapur' timestamp='1347592529' post='22010624
[quote name='tom153' timestamp='1347584407' post='22010382']
[/quote]
bottom line you dont need to remove the entire blower lol
Old Sep 14, 2012 | 09:43 AM
tom153's Avatar
Let's not grasp at straws now. Once you remove the spacer and loosen the rest of the bolts you practically removed the blower...
The bottom line is that it's a bitch and that's all there is to it.
Old Sep 14, 2012 | 09:59 AM
camuman's Avatar
1. ask tuner for base map
2. build your own from aem base map in library
3. trailer car to tuner.
