Vortech V2 install
Old Feb 22, 2013 | 08:17 AM
hvAlfaWant_S2000's Avatar
Default Vortech V2 install
Hello All,
I've been trolling the board gathering parts and finally think I'm getting there!
Just picked up a used Vortech V2 kit with 928 impl. Got the new inner and outer seals, gonna fix an oil leak on that.
I now have:
Reinhart Racing 3.4" pulley
Gates green belt
TIAL BOV
AEM series 2 EMS
AEM serial gauge - 2 gauge pod
New oil pressure sensor
ID1000s
FB 340lph FP
Onipower 3 bar map sensor
Berk 63.5 mm TP - stock exh
New K&N air filter for SC
bottle of Wetter wet
pretzels
What else do I need??
Thanks for your time!
Old Feb 22, 2013 | 09:14 AM
Thinking I'll need a breather off the valve cover and 30 amp relay for the fuel pump....
Old Feb 23, 2013 | 07:53 AM
Muggus's Avatar
Looks good to me assuming the kit has everything.
Old Feb 23, 2013 | 07:58 AM
Muggus's Avatar
Thats a pretty big pump. Maybe a AFPR
Old Feb 23, 2013 | 11:25 AM
Sure is big Mug. PO said he pulled 400+ off it.
You think I need a fpr? Figured the fb fp can supply all the pressure needed.
Old Feb 23, 2013 | 02:52 PM
Rubn1out4GudLuk's Avatar
How about a wideband?
Old Feb 23, 2013 | 04:46 PM
Muggus's Avatar
I was thinking the stock one wont be able recirculate enough because the preasure might be too high but i guess they can be modified and opened up.
Old Feb 24, 2013 | 01:13 PM
soulicious's Avatar
If your using pump gas, then I don't think that you need an AFPR since you'll be getting a new tune. If anything, your base fuel pressure will increase. That's what my calibrated AEM fuel pressure sensor indicated when running a FB340 and stock FPR. My base pressure was 58psi.
Old Mar 4, 2013 | 02:10 PM
^^rubn - do I NEED a wideband running in my ap1 with Aem V2?
I have the Aem serial gauge. is that enough?
Thx
Old Mar 4, 2013 | 06:33 PM
Muggus's Avatar
Depends if your gonna tune it yourself. Then obviously you will need one. Otherwise its really just so you can keep an eye on things. Personally I dont even use one. As long as I dont change anything the tune should stay fine. But again it couldnt hurt just to make sure everything stays in check.
