VTEC
Old Apr 20, 2010 | 11:58 AM
sworks's Avatar
No cel. I did bypass th pwr and the pressure came up so i routed through the Laminova that came with the kit. I also moved the oil sensor to the block and replaced it with the factory sensor. At idle I see 20 psi and 68-70 at 3000 rpm. At redline it drops to 50-55 but comes up to about 60. I don't know if this is normal or not. I cannot find anything that shows wat a stock motor is at redline. Many of the guys that are using oil pressure guages and a remote filter are taking pressure from a sandwich at the remote. When I did this I showed 90psi at redline. I really need to know what fi guys with remote filters and an oil cooler are getting for pressure at the block. Is this range normal?
Old Apr 20, 2010 | 12:47 PM
Spoolin's Avatar
Mine is about 30-35 psi at idle when warmed up and I use 10w40 oil and I also have a oil filter relocation kit. When first started up and cold, it's up around 80 psi. Driving, at 3000 rpm, it goes up to about 70 psi and climbs to about 80-85 psi by redline.
Old Apr 20, 2010 | 01:51 PM
sworks's Avatar
Where do you have your sensor located
Old Apr 20, 2010 | 02:12 PM
Spoolin's Avatar
My sensor is located with the oem sensor at the top of the block where the oem sensor originally went. I have a T with the oem sensor on one side and the defi sensor on the other.
Old Apr 20, 2010 | 02:20 PM
sworks's Avatar
Got it. What type of oil cooler are you using?
Thanks
Old Apr 20, 2010 | 04:47 PM
Spoolin's Avatar
Just the factory oil cooler relocated with the oil filter relocation kit. I have the Ultimate Racing oil filter relocation kit.
Old Apr 20, 2010 | 09:17 PM
X-RAYED's Avatar
The drop of oil pressure might be it.
I am wondering if you are having a problem with the oil pump itself?
edit: mine is 85-90+ at redline.
btw: I am not wandering.
swilsonsantos
Oct 30, 2018 01:29 PM
jchan727
Aug 21, 2012 12:02 PM
sworks
Apr 11, 2010 08:48 PM
SiCK HONDA
Jun 14, 2009 10:05 AM
blues2k3
Dec 10, 2005 12:15 AM
