vtec cable
Old Jun 12, 2007 | 11:27 PM
vtec-man's Avatar
Default vtec cable
Hi guys,
I would like to inform me about the vtec cable command. I searched arround the service manual but unfortunatelly i weren't able to locate this damn cable within the engine bay. I need it to activate an extra injector when the car goes into vtec to help my a/f ratio from going lean with my VTSC setup.
Thanks a lot
Old Jun 13, 2007 | 07:15 AM
macprotege5's Avatar
i am not totally sure, but i do believe vtec is oil pressure activated. i know someone will chime in soon.
Old Jun 13, 2007 | 08:49 AM
tenaciousFD's Avatar
It runs parallel to your muffler bearings.
Old Jun 13, 2007 | 08:57 AM
Ok here's a non smart-ass answer:
at the engine speed and throttle position programmed into the computer's memory map a signal is sent which electronically opens a spool valve, which then directs oil pressure to a mechanical sliding pin. This pin locks the rocker arms actuating the valves to the follower on the high-rpm cam lobe.
I'm guessing this is a facetious question since your a gold member, so, do I get a cookie for the answer?
Old Jun 13, 2007 | 10:11 AM
robodeath's Avatar
I just greased and packed mine today!
Old Jun 13, 2007 | 11:43 AM
73Zero's Avatar
Old Jun 13, 2007 | 11:45 AM
73Zero's Avatar
Originally Posted by vtec-man,Jun 12 2007, 11:27 PM
Hi guys,
Thanks a lot
Are you referring to the wiring for the VTEC solenoid?
Old Jun 13, 2007 | 12:48 PM
ChefJ's Avatar
He just wants to the wires. Its a completely legitimate question. Just trace the vtec wire from the solenoid on the front left side of the block.
brunodkid99
Jun 9, 2007 07:03 AM
DavidNJ
May 8, 2006 02:04 PM
Detroit
Jul 10, 2005 08:57 PM
StinkyTofu
Jun 4, 2005 09:37 PM
goneverything
Jul 8, 2004 04:16 PM
