VTEC, Not Engaging When It's Supposed To
I have a SOS Stage 1 on my '05 and VTEC is supposed to engage at ~4400 RPMs or so, but it's engaging at the factory setting. Aside from a bad FVM unit (the supplied pre-programmed "piggyback"), what could play a role in the VTEC not engaging at ~4.4k but doing so at ~6k?
SOS sent out a replacement FVM, so I'm hoping that does the trick but want to do my due diligence to ensure everything is properly installed. For what it's worth, prior to the SC, I was running an AFC NEO with a Boomslang harness and I had no issues with lowering the VTEC and the car responding accordingly.
Is there anything mechanical that could be the cause? What are some factors that could be playing a role?
Does the FVM box you have now, light up once installed and turned on??
What color is the light?
Green light means flash is good and everything is working!
Red light means (no flash or not communicating)
No light means unit is not working at all and something is wrong.
Check those things out on the FVM you have now and see whats up, and then do the same once the new one arrives.
