VTEC oil pressure switch with AEM EMS
Old May 21, 2007 | 07:37 AM
Spoolin's Avatar
Default VTEC oil pressure switch with AEM EMS
So everyone knows, the VTEC oil pressure switch that sticks off the VTEC solenoid can be removed if you are using the EMS. The EMS doesn't need this and adjusts VTEC by engine load, rpm, and speed. I took mine off this weekend and re-used the rubber o'ring with a large head bolt and washer and just plugged the hole. VTEC still works exactly the same and no issues.
Enjoy.
Old May 21, 2007 | 08:11 AM
PeanutButter's Avatar
would it be possible to use that as oil pressure gauge hook up or oil feed line
Old May 21, 2007 | 09:47 AM
Spoolin's Avatar
I'm not too sure about that.
Old May 21, 2007 | 03:54 PM
SOHCmyDOHC's Avatar
Enjoy.
Whatcha do w/ the connector??
Old May 22, 2007 | 05:18 AM
Spoolin's Avatar
I just pulled it back and layed it on the other wires/wire loom and ran electrical tape around it to secure it.
Old May 22, 2007 | 09:07 AM
solardodgesrt4's Avatar
AS far as using it as an oil pressure guage. I think that you would get a more accurate PSI indication from the block.
Old May 22, 2007 | 11:45 PM
Phillie's Avatar
What was the size of the Head bolt you used? Would be good to know so I can plug the hole with the right size.
Old May 23, 2007 | 05:25 AM
Spoolin's Avatar
I took the sensor to the auto store to match up the threads and if I remember right, it was an 8 or 10 1.25 with a large head.
Old May 24, 2007 | 09:17 AM
Phillie's Avatar
Thanks. I'll be re-installing everything this weekend. Got have the car ready for the 4th of june for tuning.
Old May 24, 2007 | 09:52 AM
is our oil feed on the sending unit 1/8pt?
because if it is mine sure doesnt fit right
