Walbro 255 fuel pump issues
Old Apr 14, 2013 | 03:11 PM
Kitesurfer s2000's Avatar
Explain how my stock fpr is at 78psi then at 18psi boost :-) My friends is 92psi high boost,he gained 200hp more fuel by putting it down to 50psi using a adjustable fpr .Ive been kitesurfing all weekend so i can't explain im to nackerd sorry head hurts lol
C63AMG's Avatar
Originally Posted by Kitesurfer s2000
Mine was lose as well put two clamps on the bugger.
When I swapped in the replacement pump the hose was very tight. I wonder if we, the OP and I, should use fuel line screw clamps instead of the OE spring clamps?
For the OP it's likely the pumps ability to draw the required current so a relay direct wire with 12GA wire should do the trick.
Old Apr 14, 2013 | 03:14 PM
C63AMG's Avatar
You're measuring pressure on your fuel rail? If so that's not related to pressure at the pump inside the tank.
Old Apr 14, 2013 | 05:44 PM
Irishflame27's Avatar
Originally Posted by C63AMG
How could you install the clamp incorrectly? It only goes on one way.
EDIT: Ah, I misread. The 2 clamps on the short piece of hose between the pump and the housing?
I had a very similar issue. Pressure dropping like a stone after 8k so a new pump was sent out to try. I am using a turbine driven 260lph pump (same idea as AEM, Aeromotive etc) which "should" be good for almost 600ish whp. It is directly wired to the battery with a relay and 20A fuse so there's no issue of current availability.
You mentioned the pressure increases as boost increases? I don't see the logic in that.
The car will use the fuel it's telling the pump to push (as boost increases more fuel is required). The flow will increase and the pressure, in theory, will maintain up to a certain flow rate. The pressure the pump can produce will decrease as the flow request increases. Most pumps have a flow vs pressure graph available showing this characteristic.
That's how I understand it anyway.
The way most all FPR's work in a turbocharged application is on a 1:1 rising rate. So what that means is for every 1 pound of positive pressure (MAP/boost) applied to the diaphragm, the regulator increases fuel pressure by 1 psi. This is needed because the fuel system is now trying to spray fuel into a positive pressure environment inside the intake manifold. Base fuel pressure on a Honda is roughly 43.5 - 45psi, so if you were running 10 psi,the fuel pressure would now be 53.5psi under load/boost.
This is entirely related to the fuel pump pressure. The pressure the pump is pumping is directly related to the condition inside the fuel rail. The fuel pressure is caused by the restriction on the fuel return line (ie Fuel Pressure Regulator) As the FPR opens and closes as the manifold pressure changes the fuel pump can pump more/less or maintain a constant head pressure inside the fuel system. As pressure increases, flow decreases, and walbros are terrible in hi pressure applications as they cannot maintain proper flow rates under higher pressures (boost pressure)
Old Apr 14, 2013 | 05:46 PM
C63AMG's Avatar
I did some more reading on the subject and it makes more sense now. Good link I found below if anyone is interested.
http://www.injectordynamics.com/Stec...reArticle.html
Old Apr 14, 2013 | 05:48 PM
C63AMG's Avatar
In my case pressure was dropping above 8K RPM (a little over 10psi of boost).
Old Apr 15, 2013 | 08:27 AM
shift9k's Avatar
Thanks for the responses
I'm running the oem fpr on the oem rail so base pressure I'm guessing is around 45.
I don't see much point in trying to rewire the pump, seems like a waisted effect. It looks like people are getting to my 400hp goal without the rewire. I will probably do this down the road but my main focus is to fix the issue.
I'm going to pull the hanger this week when I find some time and check all the connections.
No one thinks its a fpr issue?
Old Apr 15, 2013 | 11:12 AM
C63AMG's Avatar
I doubt you could tell by inspection if the OE spring clamp is coming loose under pressure. It's simple enough to swap them out with screw type fuel hose clamps.
Old Apr 15, 2013 | 11:38 AM
S2K-F8's Avatar
I went through the same issue on the dyno a while back (same setup also...Walbro 255, ID1000's, stock fpr and rail). We were running 12psi and I was going lean after 7k rpm or so.
Tuner suggested I add a fuel pressure gauge so we could see what was happening. I bought an AEM fuel rail, AEM fpr and a fuel pressure gauge. I rewired my pump with a relay off the battery also. Went back to the tuner and same thing happened on the dyno. We could watch the fuel pressure drop on the gauge after 7000-7500rpm.
What I did to fix the situation:
Brand new OEM fuel pump hanger
Brand new OEM fuel pump "sock" filter
Fuel line specific clamps on the small hose from the pump to the hanger
Went back to the dyno (again)...fuel pressure held (increased) all the way to redline.
I would still suggest hardwiring the pump with a relay right off the battery.
Hope that helps!
Scott-
Old Apr 15, 2013 | 01:26 PM
neeman77's Avatar
Yes I had a rewired walbro and was able to make 610 hp at 95% duty cycle on 1000cc injectors, that should solve your problems.
