Walbro 255 fuel pump issues
Old Apr 18, 2013 | 10:34 PM
  #41
shift9k's Avatar
Well I put the new clamps on tonight and wired in a relay and fuse to get 13.5 volts but every time I turn the key the 15amp fuse under dash keeps blowing. I checked for shorts but can't find any. Wired in like this...
Relay prong 30 goes to 30A fuse to bat power
Prong 87 goes to the yellow/green wire from hanger
Prong 85 to ground
Prong 86 to yellow/green from harness
This has to be correct and I soldered shrink wrapped and electrical taped all connections
I'm stumped, did I do something noticeably wrong?
Old Apr 19, 2013 | 04:58 AM
  #42
C63AMG's Avatar
The above connection is shorting to ground.
Old Apr 19, 2013 | 03:50 PM
  #43
legros's Avatar
.the s2000 fuel filtre is in the hanger
Bad design if you ask me
Old Apr 19, 2013 | 10:55 PM
  #44
shift9k's Avatar
With port 85 not connected to ground I'm getting 12 v, but as soon as I ground it out I blow the 15A under dash fuse for the fuel pump.
This lead me to believe I had a short so I ohm the wires out from the oem fuel relay all the way to the ground I have coming off the relay I added, no resistance.
I'm stumped
I am getting high resistance on the oem fuel pump relay from the black/yellow to black, but again I do get power all the way to the ground coming off prong 85 so I can't see it being the relay if its still powering the circuit
Old Apr 20, 2013 | 08:42 PM
  #45
shift9k's Avatar
Finally fixed it the relay I bought was apparently bad, although it tests good. Swapped out relays and it fired up and I must say that fuel pump sounds much more beefy
Old Apr 26, 2013 | 10:16 PM
  #46
shift9k's Avatar
Had some time to do some logging this week. It's getting lean and cutting out at 7200 randomly. Rewire did not fix my issue either. Time for a new pump
Old Apr 30, 2013 | 02:32 PM
  #47
C63AMG's Avatar
New filters and pump went in today. I stuck with the OEM harness from the pump to the hanger.
Did a street pull to 8500 and the pressure stayed solid so I think I'm good.
Retune for Monday so I will know for sure then.
Old May 7, 2013 | 05:06 AM
  #48
C63AMG's Avatar
No dice on hanger and pump. It "seemed" to be ok until things heated up. Same pressure drop but at a higher RPM.
Tried direct wire from battery and new FPR.
I have decided to go with a surge tank and external bosch 044 since this is a track only car so I may never figure out what the actual problem was...
Old Aug 1, 2015 | 06:37 PM
  #49
honda85's Avatar
Which fuel pump is better and reliable Aero 340 or walbro 225? I know both pump are different.
Old Aug 1, 2015 | 09:02 PM
  #50
honda85's Avatar
https://www.s2ki.com/s2000/topic/112...#entry23700703
Can anyone clamp in and state the Aero pump has a higher failure rate.....
