Walbro fuel pump problem
Old Oct 1, 2006 | 08:43 AM
RobbieS2000's Avatar
Default Walbro fuel pump problem
Since the install of my Walbro 255 pump my gas gauge will go down to 4 bars, and will not go down any farther. Last night when I left to go out for the night I had 4 bars of gas left, after I did a good bit of driving and was on the way home, I noticed I still had 4 bars of gas left.
I pulled off the highway to a station, and put 2 gallons of gas in, just to see what happened, and the gas gauge only moved to 5 bars, when normally on dead empty with no bars, 2 gallons gives at least 5 bars. Anyone have a similar problem?
Old Oct 1, 2006 | 08:48 AM
Sideways's Avatar
This happens when the filter sock on the pump interferes with the sending unit. It requires pulling the pump and reinstalling it making sure they don't touch.
Old Oct 1, 2006 | 08:54 AM
xviper's Avatar
When I installed mine, the float got hung up on the fuel sock. I had to rotate the fuel sock about 45 degrees to ensure the float had full travel. It's a small thing but one that some guys don't attend to.
Old Oct 1, 2006 | 09:21 AM
gotswap's Avatar
Same issue here that I caught before putting it in the tank......you will need to pull it out and fix it. I think I used a combination of my old filter with some of the new hardware.
Old Oct 1, 2006 | 11:41 AM
Should I re-use my stock sock? It is alot different from the supplied sock/
Old Oct 1, 2006 | 11:50 AM
Sideways's Avatar
That's what I did.
Old Oct 1, 2006 | 11:57 AM
gotswap's Avatar
Old Oct 1, 2006 | 12:08 PM
00S2K01S4's Avatar
I reused my stock sock. No problems with the floater.
Old Oct 1, 2006 | 07:21 PM
I got it fixed. The floater was getting caught on the sock, just a slight adjustment. Thanks for the help guys.
Old Oct 1, 2006 | 07:28 PM
gotswap's Avatar
No problem, glad we could help.
