Walnfo450
Old Jul 7, 2019 | 06:46 PM
ChefJ's Avatar
Default Walbro255
Can I install a walbro 450 fuel pump and not make any other changes to an otherwise stock ap1?
Im going to be putting together a turbo setup, and would like to get the fuel pump out of the way before winter. Thanks
Old Jul 7, 2019 | 08:08 PM
riceball777's Avatar
Wires will probably melt. A walbro 255 is about as big as you can go with stock wiring.
Old Jul 7, 2019 | 09:55 PM
flanders's Avatar
Yeah you don't want to do that.
Old Jul 7, 2019 | 10:31 PM
Kyle's Avatar
Hardwiring is your only option. A 255 will be hard-pressed to supply enough fuel for even the most mild of turbo setups, and even then you'll be pulling a good amount of current. Get the SOS hardwire kit and call it a day. It's cheap insurance. OR you can toast your wiring, lol.
Old Jul 7, 2019 | 11:02 PM
it really just depends if you plan to run e85 or not. If you don’t plan to run e85, A walbro 255 will support any Amount of power you can make on normal pump fuel 91/93 octane and can support 600ish wheel hp on high octane non ethanol race fuel.
But out if you plan on running e85 and since e85 burn 30%faster than gasoline a walbro 255 typically will not flow enough for most turbo setups.
Old Jul 8, 2019 | 12:25 AM
Kyle's Avatar
Personally I'd never try to max out a 255 on stock wiring...no need to thread the needle pointlessly.
Old Jul 8, 2019 | 04:27 AM
ChefJ's Avatar
So while I’m installing the 450 I’ll also need to increase the wiring gauge and fuse etc. got it.
riceball777
Sep 3, 2010 12:15 PM
S2000_Europe
Jan 5, 2006 07:00 AM
folex187
Jun 30, 2005 09:47 AM
S2KPiGGy
Jan 27, 2004 07:42 AM
