Wastegate spring?
Here is the email that Pang sent me
For the wastegate spring, if I remember correctly you were sent .7bar
> which has a gold and brown spring in each. The gold spring is 6psi.
> Meaning you already have a 6psi spring, just open up the top hat and
> remove the brown.
> Let me know if you have questions.
> Thanks,
> Pang
however I just checked my reciept and I was sent the W/G with .8bar, hopefully I can still remove one of the springs and have like 8psi or so?
> remove the brown.
> Thanks,
> Pang
Size, Vband, springs, lead fuel compatible..
From Tial's site
"MV-S Wastegate
V-Band 38mm Wastegate
Now Shipping in ALL Colors
TiAL will be replacing the F38 wastegate with the new MV-S wastegate. Small was on our mind when we developed this new ultra compact wastegate. It stands only 3.7" in height vs the current F38 which is 4.85" Other features include 3 bottom pressure ports for easy install and a top mount pressure port that can be rotated 6 different ways. No more bolts or gaskets and all configurations are leaded fuel safe. we also altered the way the diaphragm sits so it is virtually impossible to pinch. Now shipping in all colors."
From Tial's site
"MV-S Wastegate
