Water Spray
thats actually a good idea, i assume it helps, when i go to the track i bring a sprayer with ice water and use it in between runs. can u figure out a way to keep the wipers from doing their thing ?
Originally Posted by AusS2000,Sep 19 2005, 04:35 AM
It is a good idea but I'm not sure how hot the A-W radiator gets. I'm setting up my headlight sprayers with irrigation misters and spraying on my A-A intercooler.
With regards to the Hot A-W radiator, if the water in the washer tank is cooler then the rad, I would assume spraying would always be a + point
I'm going to have a spray bar bent from aluminium tubing and insert 360 degree misters into it. Then just connect the line from the pump to it. I will have it controlled by the sprayer switch (the dashboard mounted version) and also by a line from the AEM EMS. So it will spray automatically when I go WOT and boost is above 4psi.
Sounds like you guys are on the right track. Cooler air = more hp. Cooler air compresses easier. Thats the idea behind the aftercooler as we all know. I spent some time last year manufacturing my own nitrous and co2 kits. The use for the co2 kits was to spray on to inter/aftercoolers. co2 is around -80f when it atomizes from liquid to gas therefore making for a great way to cool off an after/intercooler. Sold around 50-60 kits before selling the company. Just submitting for consideration for you guys. Kits could be built for around 150$ and bought for around 300$.
