What is the best VTEC Engagement point for an SC
All you need is a stand alone ECU so you can adjust the fuel and timing along with the V-tec transition point. With a supercharger the F20C loves a lower V-tec engagement point but remember you need to drive on the street without V-tec some of the time. There is a limit to how low you can go and still be streetable. I have V-tec transition about 4900 rpm currently and am considering going 100-200 rpm lower now that I have big rear tires.
Check out your normal driving habbits and record the rpms you run at on the freeway, highway, etc. Keep it just above your freeway rpms.
I've got an EMS, and mine is currently set to engage at 4200rpm, 0.12 lbs of boost, and > 30% TPS, off at < 20% TPS.
4200 rpm was the point where the high and low cam's torque curves intersected on *MY* car on the dyno. With my current load and throttle position settings, I can't feel when vtec kicks on anymore. It's THAT smooth.
4200 rpm was the point where the high and low cam's power curves intersected on *MY* car on the dyno. With my current load and throttle position settings, I can't feel when vtec kicks on anymore. It's THAT smooth.
Thanks for all the replies, the general consensus seems to be that a much lower switch point is benificial.
I have a VAFC which I'm not going to use for fuel adjustment, only to alter the VTEC point.
