What HP should I expect?
Old set up:
Stock 2.0 AEM FPR Radium Fuel Rail Walbro 255lph 1300cc injectors Novi 1000 blower 3.4" pulley Small heat exchanger E85 Made 360whp New set up: Walbro 450lph 2.8" pulley Large heat exchager What HP should i expect when I retune? I'm trying to get to 450. Or as close to that as possible. |
The NV1000 drops off in efficiency pretty quick after your 3.4" pulley. I'm surprised though that you only yielding 360whp with that pulley which should have put you about 12psi, especially with a proper E85 tune. I made 360whp Dynojet at 9psi on that blower. and 375whp with the 3.4". regular 92 gas. Anyway, I wouldn't expect you to see much more then 400whp assuming you get a proper tune. Belt slip may be a factor for you in getting the full results as well. Although in 4th gear for dyno pulls its not as big of an issue as the lower gears due to the rate the engine spools up.
I'm curious to see what you make though. I tried a custom 2.7" pulley on a Novi1000 years ago just for shits and giggles but never dynoed it. |
Originally Posted by s2000Junky
(Post 24557830)
Originally Posted by ceophlo
(Post 24557831)
Do you still have the pulley??? Let me buy it.
I'll make a guess of 410hp
Can you get the blower updated to a N1200? |
Originally Posted by MARK AUS S2K
(Post 24557871)
Well then he should definitely do that but it would probably cost him $800 for blower? and $200 for plate?
(Post 24558195)
When I was S/C’d, I traded in my N1220SL for a N1200 oil-fed unit. I think cost be around $876 total. You might want to give them a call to see if you qualify for a trade-in. I thought I read something years ago that N1000s wouldn’t be able to be traded in, but hopefully that wouldn’t be the case. You will need your serial number from the blower. |
