What injectors for Comptech SC setup
Old Jan 20, 2016 | 03:12 PM
Behradsays's Avatar
Default What injectors for Comptech SC setup
Hey guys,
So, this Saturday, I'm installing my Comptech SC kit. So far, I've been trying to piece together any missing parts (since the kit was used), and I've bought a Walbro 255 Fuel Pump, new NGK spark plugs #2668 and looking into a bigger heat exchanger.
My real question is about the injectors. With about 6psi (on an ap1), what size injectors should I be running? Can I stay on my stock ones for a while? I keep reading that people are going with 1000cc but I think I eventually want to go e85, so should I start with bigger ones?
I'm going to be using the stock Comptech EMS, so I don't know what that thing can handle, as far as injector sizes.
Any knowledge on this would be great!
Thanks
Old Jan 20, 2016 | 03:16 PM
MBHs2k's Avatar
The base kit is designed to use the OEM injectors. As long as your using the rising rate fuel pressure regulator and Comptech EMS youll be fine with OEM injectors. Im running ID1000s which gives me plenty of room when the time comes to increase boost.
Old Jan 20, 2016 | 03:28 PM
Behradsays's Avatar
Okay, gotcha! That helps, thanks. I'm gonna be running the stock pulley for a while too.
So you think 1000cc is big enough even for e85? People were saying 1300cc.
I won't be going e85 for a while, but just trying to prep lol
Old Jan 21, 2016 | 12:53 AM
JJAUTOWERKS's Avatar
Former Sponsor
If your going to stay at 6psi, 1000's will be good for e85. Sending you a message.
Old Jan 21, 2016 | 02:39 AM
UberDuper's Avatar
You can (and should) stay on your stock injectors unless you're going to replace the ECU. There's no reason to consider E85 or larger injectors at 6psi.
Old Jan 21, 2016 | 10:02 AM
Spaceman2345's Avatar
I've recently installed a CTSC in my 00 s2k. I did not upgrade my injectors for two reasons: 1) I live in Cali and smog is a bitch, and 2) I'm at 5.5-6 psi, which stock injectors can handle. Unless you are upgrading to a smaller pulley you would be wasting $$$$ on injectors. I was on the same boat and jumped ship for the moment simply because of Cali smog issue. To be honest I almost jumped back on the ship last week. I was asked if i wanted to make more power,but decided that the $$$$$ involved every 2 years was not worth it right now.
What you need to worry about, which i did not at the time of install is CTs ACM unit. Might be programmed to rich.
Keep us updated bro.
Good Luck,
Old Jan 22, 2016 | 09:59 AM
Behradsays's Avatar
Good Luck,
What issues did you have with Smog? Because the whole kit is CARB legal. And any car that's 2000 and newer only gets a visual inspection and OBDII reading for CELs. They can't see the injectors so they wouldn't know they aren't stock. Unless you think they would read the ECU and see that it isn't a stock map, in which case I counter-argue with the fact that I smogged my WRX with a Cobb Stage 1 map on the ECU and it passed, no issues. So I'm not really sure haha.
Thoughts?
Old Jan 22, 2016 | 10:02 AM
Behradsays's Avatar
Well, I don't plan to stay at 6psi forever haha. Eventually, I'd like to upgrade the pulley but I know I need a standalone ECU. Just trying to prepare myself I guess.
My plan is to eventually run e85. So I guess I just want to know what upgrades I would need when that time comes. So far, ECU, Injectors and a smaller pulley come to mind.
Old Jan 22, 2016 | 11:04 AM
Good Luck,
Thoughts?
For smog,the ECU reading was my issue.
Old Jan 22, 2016 | 06:19 PM
davidc1's Avatar
I've recently installed a CTSC in my 00 s2k. I did not upgrade my injectors for two reasons: 1) I live in Cali and smog is a bitch, and 2) I'm at 5.5-6 psi, which stock injectors can handle. Unless you are upgrading to a smaller pulley you would be wasting $$ on injectors. I was on the same boat and jumped ship for the moment simply because of Cali smog issue. To be honest I almost jumped back on the ship last week. I was asked if i wanted to make more power,but decided that the $$$ involved every 2 years was not worth it right now.
Good Luck,
Thoughts?
Keep in mind that while the laws changed and say that a visual inspection and hook up to the OBD port is all that's needed...there are apparently still many smog shops that actually do the sniff test still, and you could fail if they do.
