What MAP sensor? Please advise On AEM EMS
Old Apr 6, 2012 | 05:32 PM
05TurboS2k's Avatar
Default What MAP sensor? Please advise On AEM EMS
As the title states:
I'm looking for a MAP sensor that fits in the factory location if possible and reads at 3 or 3.5 bar. I don't want to go higher if I can avoid it so that the resolution is a bit better, I figure that's beneficial and I doubt I'll be seeing more than 29psi anytime soon so even 2bar is fine.
I'd much love it to be an affordable option as well, I use AEM EMS if that makes any difference.
Thanks much for input.
-Greg
Old Apr 6, 2012 | 08:24 PM
DFWs2k's Avatar
Well you should know that the first bar is atmospheric pressure, so a 2 bar map sensor MAY read 1-2 psi more than the stock one.
Also, do you know how many increments are in between 0 and 5 volts? I'll give you a hint: you cant count that high.
This map sensor resolution myth has been greatly exaggerated.
Just get something that is plug and play.
Sent using free Tapatalk - Android FTW
Old Apr 6, 2012 | 08:52 PM
KiNgKoNg723's Avatar
SOS 3 bar mounts on factory location.. But don't take me for it!!! Do some research.
Old Apr 6, 2012 | 08:53 PM
Scienceofspeed.com
Old Apr 6, 2012 | 10:38 PM
TheCarGuy2021's Avatar
SOS
Old Apr 7, 2012 | 01:32 AM
Leviisbigred's Avatar
hondata 4bar!
Old Apr 7, 2012 | 05:07 AM
Moddiction's Avatar
Former Sponsor
Hondata or SOS. Both are plug and play and work perfectly.
Old Apr 9, 2012 | 08:55 AM
05TurboS2k's Avatar
Ah, makes sense of course. OK so post update 3bar+
Plug n play,cheap,reliable.
I figure when I can limit resolution issues I might as well, the way someone explained it was that it was more of an issue than that. Being I had stayed at under 10psi prior I hadn't had to research this issue. Sounds like that's a moot point.
Old Apr 9, 2012 | 08:58 AM
05TurboS2k's Avatar
Old Apr 9, 2012 | 11:48 AM
s2000 x's Avatar
Agree with everyone. SOS 3 bar map sensor. Sold my kits original AEM 3.5 bar for the SOS due to it being plug and play.
Mike
