What recommended spark plug for Comptech SC AP1 S2000?
Old Jun 25, 2011 | 06:26 AM
Cody Strife's Avatar
Default What recommended spark plug for Comptech SC AP1 S2000?
Hey I will keep it short and sweet, I know I probably need a two step colder spark plug, so with that said. What spark plug is recommended for the comptech SC in temperature of 80 degrees and above. I'll need part no as well. Platinum? Iridium? Or Copper?
Old Jun 25, 2011 | 06:32 AM
james0933's Avatar
NGK iridium BKR8EIX part # 2668
It's what I just picked up at advance auto for my comptech kit. They were about $30.
Old Jun 25, 2011 | 06:34 AM
james0933's Avatar
Also, this thread provides more options
https://www.s2ki.com/s2000/topic/291...d-spark-plugs/
Old Jun 25, 2011 | 06:56 AM
donaldmejr's Avatar
NGK iridium BKR8EIX part # 2668 are the ones you want...try the stock .030 gap first. Also what kind of power are you making and on what type of fuel?
Also here is my thread
https://www.s2ki.com/s2000/topic/877325-spark-blow-out/
When we talk about Iridium 7's, 8's or 9's we are normally talking about these three plugs here:
http://www.evans-tuning.com/ecommerc...nition?cat=182
Also here is a good email sent to me from Evan's Tuning about my issue.
"Iridiums are superior to copper in every way. I have never seen a copper core
plug out perform an iridium. I can tell you that going to a stock heat range
plug will make the engine more knock sensitive. All the tuning I have done with
FlashPro shows higher knock counts with the stock heat range plugs, even N/A.
There is not a resistor style spark plug in the colder heat ranges, which is the
reason for needing the iridiums. You may be experiencing misfiring issues from
the gas you are using attacking the plugs and breaking them down. Iridium is
usually much better in comparison than copper with race gas as well (self cleans
better)."
Old Jun 25, 2011 | 10:44 AM
camuman's Avatar
2668 vote here too
Old Jun 25, 2011 | 04:36 PM
joefish1298's Avatar
2668 gapped to 0.040"
Old Jun 28, 2011 | 12:02 AM
Deception's Avatar
#2668 as well, advanced sells em for $7 each
Old Jun 28, 2011 | 04:48 AM
ftpsk8's Avatar
Just picked up a set of 2668's yesterday
Old Nov 13, 2012 | 11:45 AM
kerm1t's Avatar
anyone have any input on #5311.
i just got a free set in the mail, trying to see if i should use these when installing my ctsc
Old Nov 14, 2012 | 07:05 PM
kerm1t's Avatar
bump
