Whats the E-Manage software called?
Originally Posted by JoeyBalls,Apr 14 2009, 10:49 AM
awesome thanks, I casn open the datalog window however it wont allow me to view like Intake air tem and some other things, only allows Engine speed, airflow input and output (v), ????/ is rthis because its not hooked up to my car?
now, if I plug this in to my car and only click on datalog that should gaurentee I dont mess with my tune right?
I cant get this update installed correctly, I think I have to connect my E-manage to my PC then attempt to update?
Do I need this update to just datalog?
you will need a laptop to datalog, as you cannot datalog and make changes unless you are hooked up realtime with your car.
once you are hooked up and it says online in the bottom right, save your map (save as). that way you will always have it to revert back to if needed.
Originally Posted by Chris_Lum,Apr 14 2009, 10:10 AM
you need to click one of the buttons in the bottom right of the datalog screen to open a new window which allows you to check mark the items you want to view.
Also from what I have read it will ask me if I want to import data from my E-manage, is that a yes, (data from car to pc), or do I not want to click that (take the blanks from the PC and DL it to my E-manage in my car) ?
Once you have selected the parameters that you want to log you should see a live data stream of those parameters. You will see them when the data log window is open and the car is running no matter if you have hit the start/stop button.
Originally Posted by JoeyBalls,Apr 19 2009, 09:05 AM
I plugged it in, and it says "unable to find drivers, Insert CD etc"
How do I get around that?
Also, updating to 2.2 did not delete my tune or anything.
