Originally Posted by Magics
(Post 24489376)
It's $1.4K+ what makes that so great?
Why not just buy a V1?
Originally Posted by soulicious
(Post 24489380)
AEM EMS 2 comes with the SOS stage 2 kit. https://www.scienceofspeed.com/index...all-years.html My whole point was that it’s a better deal vs a CT kit for that comes with an FMU for your tuning solution. Again, I’m not a SOS salesman as I’m turbo’d now, but it’s a solid kit. It’s straightforward to go back to stock for smog. i was on the same boat as the OP, until i got thirsty for more power. but let me get this out: got pulled over and cop tried to state ref me but noticed the carb on the vortech s/c and didn't state ref. only got an exhaust and lowered car ticket. |
The point is the sos kit isnt smog legal. Its not a practical solution to have to remove the (entire) kit and return the car back to stock every time you take emissions, especially when you can yield the exact same power potential out of a CT kit ( same blower) when your ready to move away from the fmu and supplied piggy back/stage 1 ( which does lower vtec to 4200rpm). Just like SOS stage 1, CT now comes with the added piggy back to further refine the fuel and vtec tune, giving you a good power curve in the 300whp range, unlike the old Novi1000 Comptech kits which did not, not without the aid of a vafc/neo. If you get tired of 300whp then down the road you can acquire an ems of your choice and some injectors and max the blower out, and still have a carb sticker, only requiring you to unplug the ems and swap back in the stock injectors and stay out of boost on the way to the emissions place, then go home and spend 20 min swapping back in, vs hours removing the entire sos kit, which you would have to do if there is any under hood inspection. Best case you can remove the ems/injectors and blower assy and wedge to the side loose with the oil supply still hooked up to the vtec unit and squeeze a factory intake on next to it so the car will still run and baby it to the emissions, but even that is annoying and you will dread it every time for the time you own the car. Ive been forced to do it myself in a pinch which is why im not recommending if you have a choice, just doesn't make sense to me to save a few hundred bucks down the road if you decide to boost more. Always a used EMS and injectors for sale somewhere.
LOL, you keep saying that you have to remove the entire kit. That is incorrect sir. 4 hours of time or less to be back in SMOG ready configuration (besides setting the readiness codes) is nothing once every two years. Plus, that gives a chance to inspect parts deteriorated or damaged from age, rubbing, etc. If that’s too much of a chore for something so simple, then that person shouldn’t even buy an FI kit. Spending thousands of dollars for a measly 290whp is a waste. For about $900 more (assuming new), you get injectors and EMS and close to 400whp. |
(Post 24489428)
LOL, you keep saying that you have to remove the entire kit. That is incorrect sir. 4 hours of time or less to be back in SMOG ready configuration (besides setting the readiness codes) is nothing once every two years. Plus, that gives a chance to inspect parts deteriorated or damaged from age, rubbing, etc. If that’s too much of a chore for something so simple, then that person shouldn’t even buy an FI kit. Spending thousands of dollars for a measly 290whp is a waste. For about $900 more (assuming new), you get injectors and EMS and close to 400whp. I just want to make sure the OP has a accurate full picture of what he is getting into, so he can decide what aspect he is willing to compromise on. If a carb approved system isnt important, hands down the sos kit is the best option. I have to take emissions, but they dont inspect anything under the hood or look for a carb sticker, just as long as the obd2 is in place and comes up passing, I drive off in 5 min. |
Originally Posted by s2000Junky
(Post 24489441)
The blower is plumbed into the vtec unit/engine oil and the after cooler is plumbed into the heat exchanger. What part of the kit are you planning on leaving in? And if you do the minimum required and unbolt the blower assy but resting loose to the side so you can still leave the oil system in place, how do you explain that to the under hood inspection if there is one? You are compromising potentially several points of interest, for the sake of your desire to have the op max out his blower right off the start, when the base kit will give him very close to what the op goal states without compromising anything, other then spending a couple hundred more down the road IF he wants to move to a stage 2 system. Hell I will buy the rrfpr and piggy back off him when he is ready to upgrade, that will net him more money. I will need them when I put together my 3rd supercharger for this car.
I just want to make sure the OP has a accurate full picture of what he is getting into, so he can decide what aspect he is willing to compromise on. If a carb approved system isnt important, hands down the sos kit is the best option. I have to take emissions, but they dont inspect anything under the hood or look for a carb sticker, just as long as the obd2 is in place and comes up passing, I drive off in 5 min. It’s simple...The VTEC bracket for the oil feed stays on the car. You just plug up the feed with a 1/8 NPT or whatever plug. The stock air box fits with it in place. The heat exchanger stays on the car. You just get an in-line adapter to connect the heat exchanger hoses. I removed the water pump fuse as well. |
(Post 24489450)
My desire is to provide a more productive alternative rather than settling for 90whp or CARB. That’s disappointing after spending that much money. I live in CA and had the SOS kit so I have experience with this. Have you had your s2k CA smoged and had an SOS kit? I went through four different SMOG tests without issues passing visual. As long as you have all the required emissions parts and vacuum hoses hooked correctly it’s all good. That’s what one smog tech even told me after passing knowing that I had a kit on previously before the test. Why on earth do they care about a heat exchanger, crankshaft pulley, water pump, an AN cap on the oil pan, or a S/C VTEC bracket. That has nothing to do with emissions. It’s simple...The VTEC bracket for the oil feed stays on the car. You just plug up the feed with a 1/8 NPT or whatever plug. The stock air box fits with it in place. The heat exchanger stays on the car. You just get an in-line adapter to connect the heat exchanger hoses. I removed the water pump fuse as well. |
Just go turbo...it’s better, j/k :p |
(Post 24488969)
It looks like he has an AP1. How is he going to use aftermarket injectors with his stock ECU? ;) He’s probably better off with a N1220 for his levels. For a smidge more, he can have an EMS to take advantage of lowering VTEC, adjusting timing, logging, expandability, etc. For the price, that’s better then utilizing an FMU. I’ve been there and done that. I’m just throwing my two cents since ppl end up itching for more power. Okay, I sound like I’m a salesman for SOS, lol. wait are you telling me you can run a super charger on stock ecu without a tune....(assuming ap1/ 04-5 ap2) sorry i come from an evo x and everything usually has to be tuned for AFR |
Originally Posted by toztigger
(Post 24489496)
I've been down the path of stage 1 SOS and upgrading to the paxton 1200 and standalone ecu.
I can tell you I was never quite happy with the tuning solution SOS provided with the stage 1. My vtec was acting weird cycling at engagement point. I had to crank the heck out of the fuel regulator to get acceptable AFRs. Now the car is 100% better and I love the power at ~380-400whp. |
