Where to get a WG spring
Old Mar 26, 2007 | 01:49 PM
jbotstein1's Avatar
Thanks Tim! I jsut ordered the 11.6 psi large spring. Is that correct? I have the 44mm WG. Also, if I switch this out at my friends shop can I then drive to the tuner? Or do I have to install it at the dyno? Thanks.
Old Mar 26, 2007 | 05:11 PM
afwfjustin's Avatar
It's about time you made more power...
Now I'm going to have to do this to keep up with you
Old Mar 26, 2007 | 06:20 PM
timg's Avatar
You're welcome.
That should work. As long as you're tuned for 12 psi and have no boost creep, then you should definitely be able to drive to the tuner with the spring installed.
Tim
Old Mar 27, 2007 | 02:42 AM
jbotstein1's Avatar
Justin, you're the reason I'm doing this... I have to be the biggest kid on the block
Tim, I am tuned for 10 psi, will that be okay? What if I just drive to the tuner not in boost?
Old Mar 27, 2007 | 06:45 AM
afwfjustin's Avatar
cmn
Mar 5, 2013 01:53 PM
Kitesurfer s2000
Oct 7, 2012 01:58 PM
s2kdan05ems
Mar 17, 2011 09:34 AM
JuicedS2K
Jun 21, 2010 07:31 PM
2QYK4U
Jan 27, 2007 08:22 AM
